Results 1 to 10 of 11
Thread: How was she able to run?
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Default How was she able to run?
    After the dreaded EML had come on a few times sending me into limp mode I decided I would give a few bits a clean/investigate. Replaced the vacuum hoses which were severely perished and which instantly gave back the missing power below 2000rpm.
    Constant fault code of Throttle actuator malfunction and Throttle feedback circuit malfunction.
    Took the throttle body off to inspect
    Pretty clogged up
    [IMG][/IMG]
    Inlet
    Cleaned them up and resoldered the joints on the PCB as it was off anyway
    Thought I would do the EGR at the same time as well
    All parts cleaned and put back on with new gaskets.
    Finally the boost sensor
    Before
    After
    It's amazing she kept going with all that crap in it. I got the car 5 years ago with a 1 owner full dealer service history at 80000 miles, now done 146000 and all servicing done by me, 2004 1.9 CDTI Elite estate. No history of anything having ever been done with regard to EGR, manifold, throttle body etc. Well worth doing, car feels great now with smooth power and great low down torque and only cost £6 for the new gaskets and £3.99 for a tin of carb cleaner and a bit of time.
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    never seen one that bad.
    Slough
    91 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    you have been busy then. great work and now the car drives even better than before . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Jul 2011
    UK
    Year : 06
    Nice one how did u split the egr I done mine but not that part
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    Quote Originally Posted by marc vectra sri View Post
    There are 3 torx screws to undo and it comes apart. The soot build up in between the two parts is what causes the egr to stop working as it restricts the solenoid .
    Jul 2011
    UK
    Year : 06
    Cheers al give it ago at some point mine is running sweet no lights but when I cleaned the end part I was shocked it could run
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    I thought mine was bad when i had the new inlet, but that is BAD!
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Good Grief!!! Thats unbelievable!!!
    Glasgow
    Ive never seen anything that bad, you need to drive it a bit harder to keep that from building up.
    Unless the previous owner drove like an OAP lol.
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    Quote Originally Posted by byebyeitsagsi View Post
    I'll let the wife know you said she drives like an oap.
    it's her car and she only uses it to potter around driving our daughter to all of her dance lessons and swimming etc. I only use it very occasionally as I use my passat.
