Results 1 to 10 of 11
Thread: whats this wire/connection for?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question whats this wire/connection for?
    While poking around removing and installing stuff I came across some unused connections.. Any ideas as to what they are for?
    This first one was tucked up the left hand side of the centre console behind the headunit area.. The one that is glowing from the camera flash is like a antennae type
    This second connection is in the roof console behind the mirror above the alarm sensors.. Its not for an auto dimming mirror or the microphone..
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Second photo, regensensor, is for the auto wipers IIRC
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    First picture is for a DAB unit mate, VX put this dash loom in a lot of cars, the arial one connects to the drivers footwall plug and I think it can be used for the GPS feed from the roof arial.
    You managed to get the arial wire fed through past the dash yet?
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    nevermind lol, wrong on the answer to the first one
    Jun 2009
    South Coast
    for the second one, both these pics are from my signum and it already has a factory fit CD70 and CID wiring which i use funnily enough for a cd70 and CID.. The wife has dab unit and i have not see that connection into the back of it
    As for the first one, if its for auto rain sensor I will not be bothering with that.. thanks.
    Lee, that fun starts tomorrow on the vec.. today i was just working on my signum..
    Feb 2011
    Selby
    'Regen' = 'rain' in German. Vectra Cs are built in Germany. So I wonder what a connector labeled 'regensensor' would plug into?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Found that 18 pin plug behind my dash this morning too while plumbing in my Aux in socket tray funnily enough, I assume it's for the Vx factory sat nav connection to the screen or DAB or something?
    Jun 2009
    South Coast
    Thats what i am thinking Ian. I am about to remove the last of the dab stuff from the wifes vec tomorrow so will see if this is attached to the dab module.... I have another idea of what it could be but will see when i get behind the glove box..
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I can confirm that the DAB connector is an 18 pin plug - so the connector in picture 1 does look like it could be for DAB unit.
    And I assume the aerial would be the DAB antenna input no doubt.
    Sep 2010
    6 Post(s)
    Trim : SRI
    OK, I now know that the Fakra connector will not do the GPS signal, not sithout unwrapping it from the dash loom.
    Nige, I did my CD70 today, arial, arial loom and all, the driver's footwell plug is quite simple when you actually have the time to look at it, there are 2 clips holding the arial wiring plug in, simples.
    I have ordered a fakra GPS off of eBay, that should have mine up and running lovely with the factory fitted look too.
    Fancy cutting the Rain sensor plug off for me Nige?
  1. whats the correct cable/wire
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2012, 17:56
  2. Anyone know which connection??????????
    By VECTRA1974* in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 01:38
  3. More whats the wire?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2010, 15:47
  4. Whats the wire?
    Last Post: 3rd November 2010, 15:07
  5. Is this the VDA connection
    By caravaner-tony in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 22:14
