one seems to be amplified the other isnt.
any idea what difference that makes and more importantly which i need please?
http://www.ebay.co.uk/itm/PC5-137-Va...item3ca61f5685
http://www.ebay.co.uk/itm/PC5-100-FA...item43a54f59f2
From what I read when i was hunting for one it works practically the same way that plug in aerial amplifier in the home would work and boosts the signal, so all depends if you use the radio all that much???
I do't so didn't bother and not had any issue's with receptionon my 3200bt.
HTH
Ben.
mine is the 3300bt and i do like the radio on, so the amplified is the one to go for then?
I personally don't think it will make much difference as the aerial in the Vec is pretty good anyway but for an extra 15p its worth a shot and if it don't work or interferes then you can always use it without being plugged into the remote wire anyway.
true, thank you
BTW the 3300 is the upgrade of the 3200 just allows you iPhone/iPod to connect and play videos.
Yes but the functionality between the two was upgraded as there was issue's when doing this with the 3200
and the cable can be picked up for less than that in the right places!
Linky please lol
