Thread: fault code on vec c 1.8 sri please help
    Apr 2012
    leicestershire
    Default fault code on vec c 1.8 sri please help
    Hi guys new member here,picked up vec tuesday and really like it,
    i plugged my code reader into the car the other night and 2 codes came up p1405 and p0170 the management light was not in it just had these 2 codes stored,so i erased them and been using the car and everythings been great.
    Went out in car this afternoon and the management light came on i thought great here we go again,the car was running fine may i say,plugged my code reader in and got p1405 again,any ideas please guys as need the car to be ultra reliable for the mrs to use while im working away.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    1405 is an EGR fault. Maybe needs a good cleaning or replacing. Im assuming then your car is a 2002 or 2003?
    Apr 2012
    leicestershire
    yes mate 2002 52 found where it is,whats the best way to clean it any ideas please?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Carburetor cleaner and elbow grease is your best bet.
    Heres one on a Dti, not same engine but may help. There isnt a how2 one for the 1.8, so maybe you do one.
    http://www.vectra-c.com/forum/showthread.php?t=103785
    Apr 2012
    leicestershire
    Hi guys took the egr valve off today and cleaned it as best i could i may say its nothing like the dti one in the how2 though.
    where the dti one has almost a 90 degree part the one on the 1.8 doesnt.
    Anyway i took it cleaned and sprayed wherever looked like carbon,then i removed the lower section where the egr valve sits on now thats like a 90 degree bend with 2 straight through holes which had a load of carbon in so i cleaned them out with brake cleaner wire wool and rags.then fitted back to car.
    will be going out in it later so see if any different.
    Apr 2012
    leicestershire
    been out in the car guys and no light came on after a 20 mile round trip.then got home and had to nip back out to shop and the light came on,got home and plugged it in and fault code p0170 came up.
    so ive lost the p1405 fault but the p0170 has come back.
    the car is running fine though performance side etc,it did have a very little short of mis-fire/judder once when i was driving but thats it?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have a look here http://engine-codes.com/p0170.html
    I have found on the early 1.8's the MAF causes a lot of issues, if you do replace it then make sure you get a genuine one and not a cheap ebay one.
    Also is your car heating up correctly, does it get to temp and stay there or does it go up and down, thermostat seems to go on these engines as well
    Apr 2012
    leicestershire
    car heats up fine,heaters work fine,temp goes just under half and stays there,only goes up if engines running and im in a que then only just goes just over half way
    Apr 2012
    leicestershire
    what you experts reckon then?dodgy faulty egr valve or something else?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    MAF is still my where my money would be, do you know anyone with the same engine so you can swap the maf over to try it
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
