Thread: "safeguard"
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default "safeguard"
    was messing about with my interior lights console last night,installing LED panels in the map reading lights,got them fitted nice n flush after fitting the frosted perspex,so switched on the car,noticed that the radio display (the 3 lined version,time,station,range) just came up with the time then displayed below was 'safeguard'
    so went & disconnected the battery for over an hour,re-connected & switched on the radio,now the time,radio1 & range came up as usual.......................then after a few seconds it change to just the time & 'safeguard'
    now,have i done something?,i checked the roof loom to make sure it was connected the right way & properly connected,but all looks good
    any suggestions????
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Check alarm sensors in front of interior lights..
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by ScotsDragon View Post
    Full Member spennny's Avatar
    Blantyre
    Or the big 30 amp fuses in the boot
    Sent from my iPhone 4s using Forum Runner
    Feb 2011
    Selby
    I had this too - remove the front interior light unit and unplug the alarm sensor plug. Then plug it back in again and refit the light unit.
    What happens if you press the 'disable ultrasonic sensors' button on the dashboard then shut the door and lock the car? In other words, set the alarm with the movement sensors disabled. If it doesn't show the 'Safeguard' warning when you unlock it, then you know it's because the ultrasonic sensors aren't connected properly.
    If the alarm system can't see the ultrasonic sensors when it initialises (because of a poor connection maybe) then it won't be able to set properly and puts the 'Safeguard' warning up to let you know. On mine simply unplugging them and plugging them back in sorted it.
  1. Anyone know what a "SAFEGUARD" warning in info display means?
    By andy d in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2016, 21:00
  2. Screen showing "safeguard" ??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 23:59
  3. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  4. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  5. "Safeguard Check??"
    By MikeO in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 18:11
vauxhall radio displays safeguard
