Results 1 to 10 of 18
Thread: Windscreen wiper failure
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default Windscreen wiper failure
    Has anyone ever had a wiper fail? The passenger side one give up at the weekend. Drivers side is still working and I presume they work off the same motor. The arm seems to have come loose from the motor as its just hanging there. Had a look but can't really get at the motor etc....
    Hertfordshire
    Yes m8, a couple of people have had wiper failure, we even have a how2 on replacement if you are out of warranty.
    http://www.vectra-c.com/forum/showthread.php?t=15125
    Jan 2006
    Ireland
    Cheers m8 Looks simple enough. Mines a 05 but I guess in typical Opel/Vauxhall style no known problems are ever fixed
    The Blackburn End
    Yes, I had the same a couple of weeks ago on the M40 coming back from London in the rain. I must have driven 20 miles with it before I realised.
    Local dealer did it under warranty no problem but replaced both sides and new arms, the lot.
    As long as its under warranty you shouldn't have any problems getting it done, if its out of warranty, then use the howto shown by GreenGrowler.
    Jan 2006
    Ireland
    Quote Originally Posted by SCOTTEX View Post
    Didn't notice myself....it was the wife who pointed it out when she couldn't see out
    Its under warranty so hopefully they have the parts in stock
    it's so well known that they should have...
    the wiper rack is on it's 3rd revision now..... it's the joints suffering from washout of lubricant by rainwater.. they are now sealed better..
    Regular Member hagga's Avatar
    kingswinford
    mine went in last week for the same...nice people at vx replaced whole lot..motor too.
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    had mine done last month. full wiper linkage plus motor all covered on network Q but just over £200 if not. had the same happen to me, drivers side working, passenger side failed.
    can i ask the age of your car because this seems to be a regular problem on the vectra/signum
    Jan 2006
    Ireland
    Quote Originally Posted by shillbag View Post
    Its a January 05 CDTI 150 SRi. Its in at the moment getting sorted but they're only replacing the linkage. Is it necessary to replace the motor as well?
    not at all.....in fact the linkage comes without the motor.. it's only the linkages joints that are the cause for concern
  1. Windscreen wiper linkage failure
    By Leviathan in forum Bodywork & Interior
    Last Post: 16th November 2009, 19:02
  2. Windscreen Wiper misalignment
    By KeithB in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2009, 21:45
  3. Signum rear wiper failure
    By stryker99 in forum Bodywork & Interior
    Last Post: 11th July 2009, 18:42
  4. Windscreen wiper failure
    By Hideous in forum Bodywork & Interior
    Last Post: 23rd January 2008, 17:00
