Results 1 to 3 of 3
Thread: Caliper
    Jan 2008
    GLOUCESTERSHIRE
    Default Caliper
    I had both rear calipers replaced a year ago due to them seizing.
    I have had to replace my pads twice within that time as the offside pads always wear down quick.
    Is it the piston coming out more than it should that causes this and should it be happening on a 1 year old caliper
    South east
    The inside rear pad will always wear more quickly than the outside one; as long as you aren't having to replace the pads after relatively low miles, it's the same on most Vectras.
    Jan 2008
    GLOUCESTERSHIRE
    Thanks for the reply
    Today my caliper has totally gone piston come right out and its emptied all my brake fluid through the caliper.
    I persume a seal has gone inside and thr caliper will need reaplcing?
    One question i have is this caliper was refitted at the garage for the same problem so should a brand new caliper end up the same way after 1 year?
  1. My new caliper
    Last Post: 24th June 2012, 12:47
  2. OSR Caliper
    By xoborp in forum Suspension, Wheels & Brakes
    Last Post: 12th November 2011, 19:12
  3. will i need new caliper
    By sebadee in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 02:12
  4. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
