Results 1 to 10 of 16
Thread: Can't remove my factory stereo, help.
    Regular Member muffking's Avatar
    Default Can't remove my factory stereo, help.
    Hi guys, me again (whole forum cries "Oh no, not again").
    I'm trying to remove my CCR2006 but it won't unclip and pull forward. I don't have the proper stereo removal tool but do have a pair of single DIN sized stereo removal tools that I've chopped in half to make the 4 rods that push in the stereo's holes. Do I need a dedicated Vx tool, or am I doing it wrong, or is the stereo just being stubbon.
    [Ex]Admin Duncan's Avatar
    It can be a bit stubborn, but you will find it much easier with a set of Double DIN pullers. Halfords sell a set for a few quid. The single ones should still do the job, the way you've done it, the hardest bit being pulling on all four corners evenly - which is where the double DIN pullers will help.
    Cheers Dunc. I can't get the old pullers to unclip the the clips in the back of the stereo, so I'll buy the proper ones like you say.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Two quid from halfords as D says and even then you have to be firm but fair!
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    I struggled even with the right tools I ended up removing the screen and trim above(dead easy only a couple of screws)and managed to push the unit from the back after a bit of a fight
    Feb 2006
    Wirral
    You gotta keep the stereo square as it jams dead easily.
    didn't help on mine as the cage was slightly bent I thin it had been out before!!
    Regular Member cameraman's Avatar
    Leicester
    I took the two top switch blanks from either side of the stereo & inserted my chopped up din release tool into the holes, pulled it out with my finger tips. Don't push the release tool in too far, easy to say when you've done it!!
    Jul 2006
    It's just being stubborn. It's a really snug fit, you'll have to just wiggle the unit to get it out.
    I used 2 kebab skewers! Once the catches have released, just pull it a couple of mm on one side, then the oher.
    And watch your fingernails.......
    Regular Member Ben H's Avatar
    Herts\Beds Border
    I always remove all radios from vectras with only 2 keys, the old ones that is, I must get the new ones for four holes. I've always got the glovebox out by the time I need to remove the radio during a phone kit installation.
    Insert keys down left hand side & give it a shove from behind, take the pins out & stick them down the right hand side & give it another shove. By this time you should now be able to pull it out from the front by hand.
  1. Factory Fit Stereo specs?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2012, 22:04
  2. How do i remove the stereo fascia for painting?
    By john618 in forum Bodywork & Interior
    Last Post: 5th August 2008, 14:47
  3. iPod & factory fit stereo?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 17:04
  4. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
how do i remove vectra c stereo
vectra stereo removal www.vectra-c.com
