Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 116
Thread: Y20DTH Diesel Pump
    Regular Member GMLes's Avatar
    Apr 2012
    Hayes
    Default Y20DTH Diesel Pump
    Looks like it's curtains already for my 53 plate Veccy (only just acquired). My mechanic tells me it's the fuel pump gone and his diesel pal say's it is around £1,200 on the cheap without labour. Vauxhall are supposedly around £2,000 for the same part. Anyone know a way around this as car set me back £1,000 as it is.
    Regular Member John Bishop's Avatar
    Oct 2010
    Don't know if this helps. Sorry to hear about it Les
    http://www.ebay.co.uk/sch/i.html?_nk...+dti+fuel+pump
    Oct 2010
    Read the second one down the one priced at 10p
    Apr 2012
    Hayes
    Quote Originally Posted by bishbang View Post
    Haynes say's you shouldn't remove Pump ECU and that is what this auction is for (Pump ECU Recon).
    Apr 2012
    Hayes
    Looks like i've got to sell as spares or repair for less than 1/4 of what i (Stupidly) paid.
    Gutted.
    Oct 2010
    If it is screwed then you might have nothing to lose. If they are able to sort it out and save you hundreds then brill. If its not the ecu then you will be breaking it or selling it for spares or repair anyway.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    has the car completly died or is it going bad
    Apr 2012
    Hayes
    Quote Originally Posted by peadar View Post
    At this time it runs very rough. As you power down the road it starts to kangaroo hop in and out of power. My mechanic cleared all the stored codes and keeps getting the same one coming back (P0149-Fuel Timing Malfunction) along with the EM light and Car/Spanner symbol. It stalls at idle without warning but appears a tiny bit better when warm. Already had the EGR Valve off and used a can of Wynn's EGR3 Cleaner which sorted the valve but it still keeps doing it, also my mechanic confirmed that the EGR is functioning as it should (can be heard working with bonnet up).
    Apr 2012
    Hayes
    If you watch the video for the 10p eBay listing, you can see he clips some wires to remove the ECU Module but i am not sure what these wires are and if they can be replaced easily?????
    I don't have any tools or kit to repair electronics or wiring.
    This method would save a fortune as you don't need to take off the timing chain or the pump itself.
    Has anyone on here had one done before?????
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    when my pump went the car died , it would turn over but never fire
    have you tried the crank sensor , im just thinking possitive
  1. Y20DTH water pump
    By Pingu in forum Engine & Drivetrain
    Last Post: 20th July 2011, 11:03
  2. Diesel pump
    By ads3 in forum Engine & Drivetrain
    Last Post: 9th June 2011, 18:57
  3. Y20DTH 2.0 Dti diesel fuel filter. Help needed.
    By 123rado in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2010, 21:27
  4. Need me a diesel pump!!!
    By cov in forum Engine & Drivetrain
    Last Post: 20th January 2009, 18:42
  5. diesel pump!
    By littlesxi in forum Diesel Engine related
    Last Post: 29th January 2008, 01:15
