Thread: Bump strips
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default Bump strips
    Can you remove them? Came out of work yesterday to find this I have some other little dinks as well so was thinking I might sand them down and respray them.
    Regular Member krazylegz's Avatar
    South Shields
    On a vectra b they are just stuck on with double sided tape I'd imagine these will be the same. Best remove the door card though and make sure there's no screws or clips holding them on
    Edinburgh
    Astra G you just pushed the along the length of the car (can't remember if it was towards the front or back, I think front) and then they unclipped and just lifted off
    South east
    They are glued and clipped in place. If you want to reuse them then take off the door card so you can compress the clips from inside; if you're going to replace them then you can bend them enough to be able to insert thin-nosed pliers between the door and the rubbing strip. Use a hairdryer to heat up the glue before you start pulling the trim off, the glue runs all the way around the edges of the trim.
  1. bump....????
    By mark-sri in forum General Chat
    Last Post: 3rd October 2010, 16:04
  2. Door bump strips
    By Poodle in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2010, 21:16
  3. door bump strips are they glued on?
    By Morephun in forum Bodywork & Interior
    Last Post: 31st December 2009, 10:50
  4. Irmscher Bump Strips
    By rushy in forum Styling
    Last Post: 5th March 2008, 02:51
  5. Side Bump Strips things
    By carl bear in forum Bodywork & Interior
    Last Post: 22nd May 2006, 18:02
