Results 1 to 10 of 11
Thread: help......broke down clutch pedal on floor
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default help......broke down clutch pedal on floor
    As above guys , started car ....loud noise and clutch pedal is stuck to floor ...any ideas.
    Engine 1.9cdti....thanks
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    17 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    ouch hope you get it sorted mate
    WGAF#5
    Suspect either slave or master cylinder failure...
    Jun 2009
    bradford
    Smile
    Cheers guys , well it's ok again....v strange
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Happened to mine, ended up with new master, dmf and clutch
    Jun 2009
    bradford
    Hope not Casey dmf clutch and slave were only changed 30000 miles ago
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    It was the slave causing the fault on mine so there was no point in not doing the dmf as it was rattling too. They changed the master to see if that fixed it and it didn't but the cheeky barstewards still charged me for it! I wasn't too happy as I gave them the car to fix using their many years of wisdom not just to change every random component on the car until they eventual hit on the right one... well that's what happens when the misses deals with it.
    Mar 2011
    n. ireland
    its happened to me twice i was told just lift it up with your foot or bend down and pull it back up, then was told if it stays down its the master cylinder and needs replacing, it seems to happen if your foot is slightly on the clutch so either foot fully down when starting or foot totally off the clutch
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Mine sometimes does this normally after a long drive, and on start up it makes a horrible banging noise and clutch stays to the floor than you stall it because the bite is really low.
    Am going to try a new cylinder but does the clutch have come out?
    Jul 2011
    Ireland
    Happened me one night, comin out of work, went to go into 3rd gear and pedal stayed on the floor, was my clutch master cylinder that needed replacing, easy enough to do yourself! Sorted my car, now in saving for new dmf and clutch lol
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch pedal to the floor vectra 1.8 52 plate
    By chubbs21 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 00:35
  3. brake pedal creeping to floor
    By shazaam in forum Handling & Braking
    Last Post: 14th January 2012, 15:52
  4. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
1.8 vectra c clutch pedal soft
Vectra 1.9 cdto clutch pedal on the floor
