Thread: Fault p0400 (57) (EGR Valve Voltage Low) on Z22YH
    Regular Member VeCeZ22YH's Avatar
    Jun 2011
    Bratislava
    Engine : petrol 2.2 i 155 PS
    Default Fault p0400 (57) (EGR Valve Voltage Low) on Z22YH
    hi. diagostic say that I have low voltage on EGR (z22yh) . I red a lot about cleaning or blanking EGR but I dont think this would solve my problem. can somebody give me advice. thanks.
    greet from Slovakia
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    New vauxhall fix is a egr blanking plate and a ecu software update to delete it. On the z22se and z22yh
    Regular Member borderlinechris's Avatar
    Jan 2012
    scotland/england border
    i had the p0400(egr malfunction) fault code on mine 1.9cdti sri. i stripped and cleaned it using the how2 on here as a guide, new gaskets, refitted and its been fine ever since.
    Jun 2011
    Bratislava
    thanks. would blanking plate do absolute disfunction of egr? does this "ecu software update to delete it" means dissabling egr in the ecu?
    Jun 2011
    Bratislava
    for each 10 engine starts one is bad and engine stops after accelerate.
    I have active fault : "P0621 - Generator Lamp "L" Control Circuit Malfunction
    (04) - Present" too .
    could it be the reason why voltage on egr is low?
    next fault is : "P1112 - Swirl Flap Stuck (61) - Not present "
  1. P0400-f8 fault code
    By leeeager in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 13:08
  2. EGR VALVE error P0400
    By signum_05 in forum Engine & Drivetrain
    Last Post: 26th June 2012, 22:55
  3. p0400-5a fault code
    By swvectra in forum Engine & Drivetrain
    Last Post: 12th July 2011, 06:57
  4. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  5. P0400 Fault code help needed PLease.
    By Nick1 in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
z22yh p0400
p0400 egr valve voltage low
egr valve vectra c 1.9 cdti voltage
insignia egr low voltage
