Results 1 to 3 of 3
Thread: Turbo on the way out..?
    dudley
    Default Turbo on the way out..?
    signum 2.0dti. 136K
    Have what I consider to be excess oil in the pipes (enough to coat my finger and drip off), this was from the exit hose (right hand side) from the intercooler. I have taken these hoses off many time and this is by far the most oil I have found. BUT I have no real play in the turbo shaft..?, just minimal movement, fraction of a mm in all directions,
    My car is not a daily driver and only gets used at weekends, it has however not been used/run since 20/03 (mot expired), and I found the excess oil on the 01/04.
    The inlet manifold is pretty dirty with wet oily/carbon everywhere, but I have had no smoke out of the back (black, blue or white), BUT I have been down on power,
    Question, have I by chance managed to catch oil seal failure in the early stages...?
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    or the egr is sticking / inlet coked up
    Jan 2012
    Gloucestershire
    Not familiar with the 2.0dti, but if you have oil between in the hose between the intercooler and the inlet manifold then it's either coming from dodgy turbo seals as you suggest, or from a breather from the cam cover. I would check the hose going into the turbo first - if this is oil-free, likely from the turbo - if not, maybe oil is being returned through the breather into the turbo inlet hose (if it has one, sorry, not sure on this engine!).
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
