Thread: Inlet Changed - Pics of old Inlet Split to see the crap!!!!
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Default Inlet Changed - Pics of old Inlet Split to see the crap!!!!
    Pic heavy!
    Had my inlet done, and cambelt. Car runs so much better now with the new inlet, Smoother better MPG, and in general just feels great! Think i need to doa long run for the car to get used to having it though.
    Here are some dirty pictures for all those that are considering it! My swirl bar had come off but flaps still worked flapping around!
    Dirty pictures here, No under 16s!!!!! haha
    Excuse the ****e quality! Took from my phone.
    Just for the info, There was in most are's around 1mm of ****! building upto around the 3mm area, Around the edges there was upto 5mm in places! You can see on the inlet manifold where i scraped it away into a pile, Tomorrow i will wire brush this out and gather up all the crap to show how much actually is there!
    Thats a LOT of poop in the inlet manifold!!!!!!!
    Glad mines all done now.
    Edinburgh
    How much did it cost you to get done or did you DIY?
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi m8 good post but looking at yours i am now thinking would it be poss to split it whilst on the car to give it a good clean but may be wrong though
    was there a gasket on it or just silicon bead cheers
    gaz
    Feb 2012
    Sheffield
    There was no gasket there inbetween them, I can get some higher quality pictures for people if they wish, and upload these.
    It would not be possibly to split on the car, as the fuel pump would still get in the way, along with other things.
    Cost wise, I had my warrenty cover parts.
    List of parts provided:
    Inlet Manifold
    Actuator + New arm
    Fuel pipe that comes over top (dont know why)
    Gaskets for everything
    New Boost sensor
    Several other parts
    Fitting was at my local garage, at a cost of £180.00 + Vat fully fitted. I had the cambelt and water pump done at the same time for a huge cost of ......... £120.00 + VAT fitted!
    A few other things to add, My car did not have full VX Service history when purchased, I have now had the EGR Disabled. I have cleaned the EGR twice. It has done 72000 miles, Swirl bar was off completly, and gunk was forming around the valves.
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    cheers buddy just a thought
    gaz
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    any high pressure fuel lines undone/removed must be replaced as per TIS instructions, they are a use once only affair... 2nd'ly how did you get the EGR disabled, just a semi-blankinh plate or remap?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Feb 2012
    Sheffield
    Quote Originally Posted by plasma View Post
    Remaped at MAS with EGR Disabled.
    Do we know why mate? I didn't replace mine when I changed in manifold and it's been fine for the last 12k miles...
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    its due to the high pressure of the fuel as you know and they say to change them otherwise they could start leaking because of bad refitting. (ie may squash up slightly when installed/deform etc etc) so new ones required, many ppl have refitted without a problem, same as caliper carrier bolts they same change them everytime but most people dont.
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    I thanked cos i thought it was just me who didnt change them haha.
  1. timing belt changed with inlet?
    By hairy31 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 13:20
  2. just changed inlet manifold cdti 150
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 20:09
  3. oil at top of inlet
    By neill in forum Engine & Drivetrain
    Last Post: 22nd February 2011, 23:15
  4. Pics of the new inlet manifold (cdti)
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2010, 15:53
  5. Cleaning the inlet manifold on the V6CDTi - Pics inside
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:02
splitting and cleaning inlet on corsa c
