Thread: Rear caliper slides.
    Aug 2010
    Leeds
    Default Rear caliper slides.
    Just done rear pads on Vectra 08 plate worn at 21k anyway the caliper allen key bolts that should slide in the caliper are very tight had to knock them out.
    In the past the 20 yrs of doing cars i never had a set this tight are yours the same or have i got a duffer?
    O/s/r was the worst one i filled out the slides and lubed them up they do slide now but not as easy as they do on a ford.
    Good deal on pads at vauxhall got a taxi discount for cash, nice one.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    You need to remove the slide rubbers and remove the corrosion from the calipers inside with sand paper or a file, then grease them up and they will slide freely.
    Aug 2010
    Leeds
    Ok do they just push out with a tap or two from a hammer?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    I used a small flat screwdriver to push, prise, them out. I cleaned mine out 18 months ago and had to redo them a couple of weekends ago. I put a thin coating of copper grease inside the holes this time to help prevent further corrosion.
    Aug 2010
    Leeds
    Thanks for the help.
    Regular Member IDVAC's Avatar
    Apr 2011
    northeast
    caliper slides seize regular ime
    occasionally have to drill them out
    Aug 2010
    Leeds
    Just done this while the wheels were off for the new tyres, loads of corrosion and filed them out clean with a smear of copperslip put the seals back in.
    Nice and free now was grabbing the disc slightly.
    Thanks for the photo above you made it simple.
  1. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  2. Rear caliper
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 23rd September 2012, 09:42
  3. Rear end slides
    By SIG53 in forum Handling & Braking
    Last Post: 11th July 2007, 20:57
vectra c rear caliper slide seal
