Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: Jerky engine 30 seconds after starting.
    Regular Member Mark1892's Avatar
    North East
    Default Jerky engine 30 seconds after starting.
    Hi everyone, done a quick search but didnt really find any posts with same symptoms. 2003 1.8 LS petrol starts first time every time but then after about 30 seconds of starting the engine revs dip and raise and if i have pulled away the car jerks ridiculously as if i'm a new driver that doesnt know about clutch control. this lasts only for approx 10 seconds then after that perfect driving. No warning lights or fault codes present so am pretty clueless to what it is. first thought was maybe coil packs or ignition module????
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    oops hit the worng button there...
    I would start with cleaning the throttle body out and changing the fuel filter.. Does it do this when its a warm start or just cold starts?
    North East
    Quote Originally Posted by Caveman_nige View Post
    just from cold mate
    May 2011
    rochdale
    Egr maybe?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Have another Thanks button hit.
    I too think fuel problem, but maybe also outside chance of problem Battery.
    Power Assist Steering takes a lot of amps, which is why I am thinking Battery not recovered from starting the engine and alternator cannot supply enough power to charge battery and PAS with voltage drop.
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    coolant temp sensor faulty switching off cold start extra fueling too early ?
    North East
    plenty to think about there chaps, thank you. will whittle through your ideas. just seems weird starts perfect and idles perfect until something kicks in or kicks out.
    North East
    Quote Originally Posted by Mark1892 View Post
    just from cold mate
    i dont mean just on cold days, just when engine is cold. does it on hot days too.
    North East
    Quote Originally Posted by swilky23 View Post
    Egr maybe?
    Pretty sure where the EGR is supposed to be I just have a blanking bolt held in with 3 torx bolts.
    anything else i should try cleaning as well as filter, throttle bodies???
    Feb 2011
    Selby
    If you keep the revs down (ie below 3000rpm) until you're past the time that it normally does it, does that stop it happening?
    Another thing to try - when you start the engine, let it idle until the revs drop from just over 1000 to under 1000 (about 10 seconds or so usually). Then try driving off.
    My 1.8 used to have a slightly jerky phase after cold start in exactly the same place on the road (probably about 30 seconds after starting) - but letting it idle and/or keeping the revs down it's not done it for ages. I put it down to spark plugs by the way - and will be changing them at some point soon. Going to pass 100,000 miles on my way home tonight!
  1. Replies: 5
    Last Post: 13th May 2012, 18:58
  2. Engine Starting
    By Mark2.2 in forum Petrol Engine related
    Last Post: 5th December 2011, 15:28
  3. Starting - engine juddering
    By GWHIZZER in forum Engine & Drivetrain
    Last Post: 16th July 2009, 14:50
  4. engine starting
    By chappie in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 18:10
  5. Engine not starting
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 29th April 2007, 13:46
vectra c 1.8 jerky
car engine stop after starting z18xe
