Results 1 to 10 of 14
Thread: piston rewind tool size
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    Question piston rewind tool size
    Hi,im going to change my rear pads and discs on my signum 56 plate cdti at the weekend and before i start can somebody tell me what the distance is between the pins on the tool from center to center as ive got one thats 22mm but not sure if that is the right size ? many thank`s Steve
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If you have a sealy set its the same size as the actual rewind tool itself (about 19-20), but there usually easily done if not siezed with pliers.
    Apr 2009
    CO DURHAM
    Quote Originally Posted by the-wizard View Post
    its not a sealy set it a home made one that fits on to a ratchet,thanks for your quick reply wizard
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    18 mm centre to centre
    Apr 2009
    CO DURHAM
    Thumbs up
    Quote Originally Posted by markj23 View Post
    Cheers mark i wonder if i could use a peg spanner to wind it back then that should do i hope
    Aug 2010
    Luton
    not being funny all these fellers saying use this or use that " it's easy " yes it is till it goes wrong and you cant wind it back and your car is on stands and your snookered and end up having to pay top dollar for the kit. It take a fair amount of force to get them started winding back in. I would search for the kit or try to borrow one if I was you just in case its sods law it will go wrong without a back up plan (just my advice been in position above)
    Apr 2009
    CO DURHAM
    Thumbs up
    im thinking along the same lines as you mark there is nothing worse than being caught out in one of these situations.Think i will have a search for one !Thank`s again
    Apr 2009
    CO DURHAM
    Does any one know where I can get a cheap one of these or have one for sale
    Cheer`s Steve
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    128 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    i agree with you there with the pliers i did mine the other day, if using pliers the trick is to turn the piston 10mm (no more ) anticlockwise and then turn clockwise to wind them in
    i could not get mine to go in at all until i found this trick
    to be honest with you winding the piston in is the least of your worries as getting the caliper carrier torx bolts to move without slipping are the worst bit due to lack of room and how tight the ******s are
    Swanley , Kent
    128 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by stevie1 View Post
    Cheer`s Steve
    does this help?
    http://www.ebay.co.uk/itm/Laser-4057...item43a556239f
  1. Piston Rewind Tool Vectra C
    By Lewki in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd June 2012, 20:41
  2. piston rewind tool
    By brtsam1 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 20:39
  3. Piston Rewind Tool
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2012, 13:07
  4. Piston rewind tool
    By ickleric in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 11:28
  5. Piston Rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 10:58
