Results 1 to 10 of 13
Thread: Change of wheels - calibrate speedo?
    Regular Member cossie's Avatar
    MANCHESTER
    Default Change of wheels - calibrate speedo?
    I am really undecided as to which wheels to keep at the minute. I had both sets up for sale in the For Sale section but both have pro's and con's!
    I am currently on my 18" multispokes with a tyre size of 225/35/18 (wheel and tyre diameter is 59cm). The originals are 215/50/17 (Wheel and tyre diameter is 65cm) The 18's give me a good clearance for lowering if I want to later on but the ride is very firm. The 17's are stock, a bit boring but a more comfortable ride.
    Because of the difference now in total diameter, it looks to me like the speedo is now really over estimating the true road speed (I would say a true road speed of 25mph is displayed around 30mph on the clocks). This gives me some problems in speed determination in traffic etc, but more importantly it will clock up the mileage more than it should. (Although my fuel consumption will be better indicated on the BC - ha! )
    I have read somewhere that there may be an option in tech 2 to change the wheel/tyre diameter to calibrate the speedo to a more accurate reading? Is this true and if so anybody near Manchester/Cheshire with Tech 2 to do that for me for a few beers??
    Thanks in advance
    Paul
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Should you not be running 235/40/18 to keep speedo right.
    Full Member coldo's Avatar
    Scotland
    Quote Originally Posted by ScotsDragon View Post
    I changed mine for a set of Astra wheels... Pentas with 225/40/18
    I have checeked the speedo against my sat nav speed and it is the same before and after at all checked speeds (20, 30, 45, 60, 70 and above). I check it becuase I was a bit parraniod to be honest.
    I also used my op com to change the wheel size setting on the ECU (cant remember where the option was)....
    hope that helps.
    MANCHESTER
    I agree they prob should be 40 series profile, but the wheels came with 35's in good condition - seemed a shame to ditch 4 good tyres.
    So it can be doen with Opcom then - anyone have Opcom/Tech 2 that may assist then please?
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Quote Originally Posted by cossie View Post
    Paul
    Paul two questions:
    Are you sure the diameter on the 18's is 59cm, I make it 61.5cm
    Are you sure the stock / factory set up is with a 215/50 profile? I thought they were 225/45's?
    If so that brings the two much closer together and if stock is 215/45 then the difference is neglible!!
    Oops looked at a few other posts - I'm wrong - ignore me..............
    MANCHESTER
    Quote Originally Posted by Chris B View Post
    Paul two questions:
    Chris
    The stock wheels I have just taken off are definitely 215/50/17 Chris. And as best as I measured the wheels on the car this morning 59 was within a good tolerance Chris.
    Jan 2012
    Essex
    Chris
    Yep sorry, my mistake
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Should be 225(235)/45/18 as per the handbook
    The 235/35/18 is much too small and you may not even be able to match this size up with Tech2/Opcom/Vauxcom
    Sell the tyres you have and get some correct size ones
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Check here: http://www.etyres.co.uk/tyre-size-calculator.htm
    You will find your current tyres are 25mm out comparred to your old ones and as such are not recommended to be used
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    on my old vectra I used op-com to go from 16's to 19's and it was fine. see if you can get someone with op-com/ tech2 to change it.
  1. Speedo Change
    By 11mallard in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2013, 23:35
  2. speedo change
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2012, 02:40
  3. Speedo change
    Last Post: 8th July 2012, 20:57
  4. speedo change
    By d8mof in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 21:44
  5. Dumb Question? Change wheels, reprog speedo
    By Leviathan in forum Handling & Braking
    Last Post: 15th February 2008, 21:05
opcom wheel
change wheel circumference tech2
change wheel size in opcom
opcom wheel size
opcom change tyre size
set wheel size with opcom
vectra c program wheel diameter
