Results 1 to 10 of 24
Thread: Gutted - Alignment
    UK
    Default Gutted - Alignment
    Well I thought I was doing the right thing getting my alignment done before the Easter break as I've got a fair bit of long journeys to do. Took it to a place in Droitwich with a Hunter system this morning first thing. All was going well, the fronts where fine apart from the steering wheel wasn't pointing straight and the back camber was miles out and needed adjusting, this made me happy knowing something was out and could be adjusted. What didn't make me happy is seeing my rear cam adjuster bolt snap and fly across the floor. Gutted.....
    Slight problem getting hold of the cam adjuster bolt (not until Tuesday) and the lower arm bush was knackered and needed a new arm. First lower arm to arrive was the wrong one, so they are trying to get another one. I've asked if they can put in just another bolt instead of the cam adjuster bolt so at least I can use the car over Easter.
    Now I wish I waited until next week to do the alignment.....
    Jun 2011
    Herts
    guted for ya fella :-(
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Seems to be a common issue with the adjuster bolts. :/
    UK
    I think its going to be good advice to anyone going to have their alignment done to pick up a couple of camber adjustment eccentric discs and bolts before they go, just in case....
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I'm in same boat... Waiting for my arm to get delivered.
    What do you mean wrong arm? Hope I get the right one now lol.
    UK
    Just got this from the local dealers, its shows the rear suspension, is it number 20 and 21 for the camber adjustment.
    UK
    Quote Originally Posted by leemarksmith View Post
    I wasn't there when the wrong arm was delivered, but when i got there they said it was wrong and needed a different one, maybe it was for a later vectra, not sure.
    18 Post(s)
    Mileage : 110k
    Hope it's not trim specific etc!
    Engine : 1.9 CDTi
    Probably sent an upper banana arm.
    UK
    Got some more info about the eccentric cam/bolt. There are two lengths for number (20) in the PDF I posted, 85mm and 100mm, parts numbers 24422972(85mm) & 24422973(100mm). They come with number (21) so you don't have to order them individually.
    My local dealer cant get them until Wednesday.
  1. gutted :'(
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 22:06
  2. Gutted
    By PORKBALLS29 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 19:00
  3. Gutted
    By willoftoon in forum The 'Off Topic' room
    Last Post: 18th July 2008, 19:54
  4. Gutted
    Last Post: 18th July 2008, 13:00
  5. gutted
    By don paul in forum The 'Off Topic' room
    Last Post: 5th May 2008, 21:23
