Results 1 to 10 of 16
Thread: Valve Clearance check with Cambelt change
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Default Valve Clearance check with Cambelt change
    I'm getting my cambelt changed shortly, my cars coming up to 80k and I'm not going to wait until it gets to 100k as per the manual.
    On some posts on here people have said the valve check can cause issues while others say it doesn't.
    Any experiences and recommendations?
    The auxiliary belt is due at 80K miles, the cambelt is not due until 100K miles
    The cambelt on this engine will easily get to the 100K miles
    I had mine completed at 90K miles, as this was the nearest service interval (the next would have been 120K miles)
    If the auxiliary belt has not been changed, then do that NOW, although you could have both done at the same time
    Also have the (auxiliary belt) tensioner examined, this doesn't last much beyond 100K miles and once worn will scream it's head off
    Alternatively you could include this
    As you have rightly seen from the Service Schedule, the cambelt includes checking the valve clearances
    The dealership I use overlooked this and wondered why the cambelt change took them just two hours, when the booked time was six hours
    I questioned this and they then completed this additional work
    Shortly afterwards my engine suffered the blocked SCV issue
    Whether this was from the cambelt work (and associated checking valve clearances) is debatable
    The dealership advised it was very unlikely and never provided a confirmation of this
    Furthermore, the response I received from VX was not much help either, it simply advised the faulty SCV had been replaced as per the warranty (which I already knew)
    Sep 2010
    6 Post(s)
    Trim : SRI
    I'm going to get it done at Vauxalist in Loncoln, £170 for a full service, just waiting on the price for the cambelt etc.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mate, yours is a Z30DT and has hydraulic tappets
    Oct 2010
    Lincoln
    Quote Originally Posted by lee_umney View Post
    Just about to get mine done at the same place, pretty sure Leo quoted me around £250.
    Regular Member John Bishop's Avatar
    Oct 2010
    On a 3.0 V6 I would be suprised if £250 covered the labour costs at a vauxhal dealer
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by bishbang View Post
    It'll only take an hour to do a v6 cdti belt kit.
    As water pump is driven internally so no set time to get it changed.
    And crank to fuel pump is also gear driven. So belt only goes from fuel pump round cams.
    One of easiest belts out their to do
    Quote Originally Posted by Celes View Post
    Doh, assumed the OP had a copy of the Service Schedule for a Y30DT, hence the question!
    On a Z30DT that should cover both the part (cambelt kit) and labour
    Oct 2010
    Oh right. TIS indicates 6hrs for all belts, tensioners and checking clearances
  1. Can I check if my cambelt has been done?
    By ficosaneil in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 12:00
  2. Can i check my Cambelt easily?
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 20:35
  3. V6CDTi - Valve clearance values - URGENT -
    By Celes in forum Engine & Drivetrain
    Last Post: 31st January 2011, 12:29
  4. adjusting valve clearance 150cdti
    By hairy31 in forum Engine & Drivetrain
    Last Post: 12th January 2011, 20:08
  5. egr valve check
    By dazcdti in forum Engine & Drivetrain
    Last Post: 28th November 2010, 14:12
