Thread: Spanner light no codes
    Jul 2009
    Brighton
    Default Spanner light no codes
    Well, got the spanner light on, but no codes are present. Used an Autel code reader, but nothing there. Even when I clear the previously stored code (light goes out then eventually come on again).
    Car seems to drive fine, maybe a good thrash might help.
    Recent history:
    Jan - cleaned EGR + fitted Fiat gasket
    Also boost sensor. Gave an error code as I'd fogotten to reconnect the plug.
    March - Cleaned MAF sensor (contact cleaner sprayed at a distance). No problems with that!
    Always use Shell, but recently been using two stroke oil (only 200ml per tank).
    Any ideas?
    Oh, last time I looked, swirl valve bar was still on (been replaced couple of years ago).
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    try a new fuel filter mate .
    Jul 2009
    Brighton
    Had a new filter on a year or so ago. So could be that.
    Typical as I'm off for the weekend to Nottingham to see relatives, so need to car to last 200 miles and back.
    Regular Member bigalec's Avatar
    Feb 2012
    prestwick
    Trim : SRI 1.9 CDTI 16v
    i had spanner light on come on!! 1 was for a very little drop of water in my fuel filter and the other time it was 1 of my glowplug .. but if it's the glowplug it wil go out after about 1-2 mins of driving !!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    it will defo be a for a glow plug fella try activating the glow plugs a a few times before you actually start the engine bet ya the spanner light dont come on if you do this
    Jul 2009
    Brighton
    Strange as it came during my journey (and not the start). Although doesn't rule it out though.
    It had the glow plug relay box done 3 years ago (same time as the inlet manifold).
    I'll check the plugs later and then drain the fuel filter next.
    Thanks for the responses.
    Jul 2009
    Brighton
    Just checked the car.
    Key in ignition and waited 5-10 secs, then started with no EML!
    I'll see when I drive home tonight if it stays that way.
    Just noticed that the MPG was down quite a bit, so not sure if it's done a regen or gone into limp mode. Although the engine didn't feel any different!
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 0
    Last Post: 26th August 2012, 03:15
  3. No codes being displayed - Spanner light
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2011, 22:41
  4. Spanner light - no codes
    By dickybow in forum Engine & Drivetrain
    Last Post: 6th May 2011, 20:58
  5. Spanner light/limp home/fault codes?
    By Factory Pilot in forum Engine & Drivetrain
    Last Post: 17th June 2009, 09:09
vectra c spanner light
