Thread: re swirl valves
    Nov 2010
    manchester
    Default re swirl valves
    do the cheap fix with the washers on my swirl valves, but the ****** keeps faling off one of them, as i understand it they just inturupt air flow at low revs (turning a 16 valve into a 12 valve so to speak), will the diesel run without them?was thinking of just removing the butterfly ,so its allways open ,before i do this has anybody else done it ? did it cause any rough running,or other problems??
    thanks in advance
    steve
    ps. have just checked the other threds regarding glueing in open possision, i reall was thinking of removing the butterfly bit completly, so there is no chance of anything breaking up and doing any eng damage
    May 2006
    scotland
    I can sort of remember one thread whereby someone removed them but cannot remember if it were here or on a BMW forum.
    As you said, you have looked at some threads about glueing them open. I for one have done this (1,2 & 4). Car runs fine and even better now that I have disconnected the EGR connector. Mine are glued in the open position but I guess if you wanted to trial which positions work best for your driving, you could try different positions (ooh err) using a wee bit of gaffer tape to temp hold them in the position you want to trial them at.
    I must admit it was a little disconcerting as I watched the superglue run into the gaps but was fine and it has sealed the gas leak also.
    Nov 2010
    manchester
    thank,s but was a little bit concerned that as they are intakes did not want anything solid getting sucked in and damaging the eng,though well if glueing them open (& no ill effects)next step is to remove completly,and then seal top hole up.but no threds seem to have gone that far
    West
    Harvey Smith has gone to the leangths of modifying a used manifold to remove flaps / plug & weld the holes... mine have been bonded into the open position & done over 10k like this with no ill effect
  1. Swirl valves on an '08
    By stevoxsi in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 22:11
  2. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  3. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  4. Swirl Valves
    By dhwigston in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 15:13
  5. swirl valves
    By scoobyman in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 21:14
