Results 1 to 10 of 18
Thread: Replacing bulbs with LED's
    Regular Member GMLes's Avatar
    Apr 2012
    Hayes
    Default Replacing bulbs with LED's
    Hi all, just a quick one for you all. I have seen that there are a lot of LED bulbs on the market as direct replacements for the Vectra C. Mine is a 2003 (53 Plate) 2.0DTi LS spec hatch and i need to know if this car has a bulb failiure system/computer onboard. A lot of the bulbs i have seen say that they are not suitable if so.
    Has anyone done this mod yet?????
    I am looking to replace......
    Front sidelights
    Front indicators
    Rear Reverse
    Rear Brake
    Rear indicator
    Rear fog
    Number plate
    Thanks guy's.
    Regular Member John Bishop's Avatar
    Oct 2010
    Not sure but try taking a bulb out and start her up. If no message comes up then there is your answer, possibly
    Apr 2012
    Hayes
    Quote Originally Posted by bishbang View Post
    Will check it out asap. The majority of bulbs will need resistors if it has Canbus (Bulb failure system).
    Apr 2012
    Hayes
    Would the necessary resistors be easy to fit?????
    Oct 2010
    Interior and number plate lights are ok apparently even with full canbus. There is a How2 about fitting led's and shows you how to fit resistors on here regarding the sidelights. If yours is a half canbus you might be ok.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Side lights and number plates will flash unless their turned on.
    Even with 55ohm resistors.
    Also not sure I'd trust brake lights since vectra is a bit twitchy on led bulbs
    Apr 2012
    Hayes
    Quote Originally Posted by Critch View Post
    Number plate and reverse bulbs are apparently suitable for use with canbus.
    When you say 'Vectra is twitchy' and 'they flash', can you explain a little more????
    Oct 2010
    You might not have both rear fogs working. They cut costs after a certain year and only connected the offside one.
    Apr 2012
    Hayes
    Can always check.
    11 Post(s)
    I thought all Vec-C's only had one working rear fog when they left the factory.
  1. GU10 bulbs - LED's
    By Leemarksmith in forum General Chat
    Last Post: 3rd June 2010, 23:55
  2. Replacing bulbs in sunvisor mirrors
    By James24 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2009, 13:37
  3. Replacing sidelight bulbs
    By mishima in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2009, 01:24
  4. Replacing Number Plate Bulbs...
    By Dan_BlackSRi in forum Bodywork & Interior
    Last Post: 14th August 2009, 20:05
  5. Replacing interior map light bulbs
    By stehanson in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2006, 18:25
