Thread: Navi 70 Aux In
    Regular Member leedrummond's Avatar
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Engine : 1.9 CDTI 8v
    Mileage : 150,000
    Default Navi 70 Aux In
    Hi, i own a 2007 Vectra
    im wanting to use the Aux in to connect my phone, will my radio have the 3.5mm jack socket on the back already being 2007 model?
    Aux in is not enabled on my head unit i see so i may need to get that activated too..
    can anyone guide me here ?
    Dec 2011
    Seaham
    You will need to have the latest software, then it has to be Tech 2 to show up in the menu and finally you will need to solder some surface mounted components onto the main board. Oh and wire in an auxiliary socket. The components were available on Ebay.
    May be easier just to use a small transmitter?
    I have a Navi 70 and havent bothered.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i also wanted to add aux to my nav70 but looks a pain. ive tried one of them fm transmitters but it was crap.
    Dec 2011
    Seaham
    I have used FM transmitters with good results on my MP3 player. Got to choose a frequency well clear of normal radio stations.
    I believe there is someone on here that can do the conversion for you?
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    it would be less hassle to fit an aftermarket head unit with an aux in surely?
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Ben50n what FM transmitter have you got?
    Dec 2011
    Seaham
    Mine is called an Istuff? In fact I acquired it from an ex-girlfriend. So it was free!!
    As stated above the trick is to find a good clean channel well away from other main radio stations.
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    I have attached some pics of what i found behind the head unit dont know if its a simple connector i now need seen a few things on ebay but unsure
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    also these if they help ?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Try searching on aux in mate as yours is pre 2007 you will need this thread as aux in is not compatable in standard for for your HU.
    http://www.vectra-c.com/forum/showth...highlight=cd70
  1. Cd navi 70
    By andyco11 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 15:15
  2. CD 70 Navi
    By simsr4 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2009, 22:55
