Results 1 to 3 of 3
Thread: Timing Belt Replacement -Crank pulley removal
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Default Timing Belt Replacement -Crank pulley removal
    Hi, About to do the timing belt on my 2004 1.9 cdti 120 and doing my homework before I start - There are loads of previous posts and an excellent How Too on this but I can't determine when removing the Crankshaft Pulley - do I have to remove the bolt or can I just remove the four torx bolts that hold the pulley onto the crank. I would have thought that the large bolt would be best left where it is as I will need it to turn the engine over to line up timing marks and then to turn the engine over to make sure it is turning over without fouling anything, when the new belt is on. Thanks
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    4torques just to do the cam belt
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Cheers mate
  1. z32se timing belt replacement
    By shadow.warrior in forum Engine & Drivetrain
    Last Post: 18th October 2015, 11:37
  2. Timing Belt Replacement
    By Dave_G in forum North East RO Vacant - ARO - Vacant
    Last Post: 25th November 2012, 12:34
  3. Aux/Drive belt tensioner & pulley replacement
    By Marky in forum Engine & Drivetrain
    Last Post: 5th October 2010, 20:43
  4. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
crankshaft timing belt pulley vectra c
