Results 1 to 10 of 17
Thread: CDTi 150 - Abit laggy?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default CDTi 150 - Abit laggy?
    My Dad says his 06 CDTi 150 Elite Estate has started to feel abit laggy.
    We were out this afternoon in it and yeah in a way it does feel abit gutless low down, but the turbo seems to be OK as you can feel it pull when it kicks in.
    He also had a couple of random occasions a few weeks ago when under acceleration, quite a large cloud of white smoke came from the exhaust.....I put that down to the fact that he (In a monent of madness) had put supermarket fuel in just before that, he said he was in the red and was there so stuck some in!!!(Pillock)
    I've been out in the car with him, and on my own and have never seen this happen or made it happen, and it seems to be running ok, but not sure if it's lacking low down really as i dont drive it that often.
    It is on 82k miles, is serviced every year on the dot, the coolant never drops, oil is fine.
    any ideas what could be the issue here?
    Thanks in advance
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Few small things you could do yourself
    - EGR Valve, Remove this, clean it out (give it a ****** good cleean, as they can get filthy)
    - Throttle body (same as above, give it a good clean)
    - The sensor to the side of the EGR (Boost sensor) only 1 bolt, Give that a good clean too. How2 Link
    - Run a good fuel additive through it aswell (i use the millers one) and not supermarket fuel.
    there are some other How2s in the how 2 section, but for some reason i cannot see the relavent ones (im going blind, im sure)
    The smoke could have been from a DPF Regen (if this car is fitted with one)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Never had a problem with Supermarket diesel and we do 30k+ between my wife and I on it.
    I would run some BG 244 cleaner through it, IMHO much better than Millers by miles.
    http://www.powerenhancer.co.uk/produ...l-fuel-cleaner
    Also are the journeys all short or is there any long motorway driving involved.
    Modern Diesels do not like short journeys all the time which can cause them to basically clog up.
    I would do as recommended by Dane-10 but use BG 244 instead of Millers
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    what cured my very bad flat spot was diesel and air filter. But if its been service recently then cant see it needing them.
    Also have a look to make sure the swirl bar hasnt come of, also check for an oily residue around the swirl valves
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    I reckon your dpf might be a bit clogged!
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by Dane-10 View Post
    - EGR Valve, Remove this, clean it out (give it a ****** good clean, as they can get filthy)
    Thanks Dane...possibly do the EGR and TB at some point...Boost Sensor was done not too long back, might do it again just to see what it's like.
    I should have mentioned in the thread that i put some addative through it, Wynns Injector Cleaner....and he only uses Shell from now on.
    Yeah it has a DPF, but surely if it was a regen, it would have smoked all the time, and also the coil light should flash on the dah when it's doing a regen, and my Dad said no light came on.
    Quote Originally Posted by merikiito View Post
    Thanks merikiito...I'll have a look at that stuff....and the jouneys are not all that short really, although it doesnt get much motorway work or long runs tbh
    Quote Originally Posted by neill View Post
    Thanks Neill...Service wasnt too long ago so all should be well on that front...I'll have a look at swirl bar over weekend.
    Quote Originally Posted by Richard.roberts View Post
    Thanks Richard, another area to check
    Northampton
    Engine : A20DTH
    Mileage : 88000
    "Yeah it has a DPF, but surely if it was a regen, it would have smoked all the time, and also the coil light should flash on the dah when it's doing a regen, and my Dad said no light came on."
    Vauxhall took the decision to remove the light during a regen because people kept bringing their car back because they thought something was wrong. What was wrong was the fact that they did not read the manual!
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    All facelift estates come with dpf
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Oh thats marvellous!!
    Mind you, half of the F***witts on the road don't know the highway code, so reading their actual cars manual would be a hard thing to do.
    So no cars have the coil light flashing during the regen then?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by MadOnVaux! View Post
    Some older ones might but I think there was a software update which turned the light off.
  1. 1.9 CDTi 120 Seems abit sluggish....
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 12th November 2012, 17:14
  2. Having abit of fun lol
    Last Post: 29th June 2012, 19:36
  3. need abit of info if anyone can help.!!
    By Vectra boy in forum General Motoring Chat
    Last Post: 4th November 2011, 20:20
  4. 1.9 CDTI 150 - Smoking/Sounding abit pants
    By SamT in forum Engine & Drivetrain
    Last Post: 22nd September 2010, 08:39
  5. 1.9 150 cdti owners, abit of help please
    By shake in forum Diesel Engine related
    Last Post: 6th December 2006, 08:13
