Thread: mirror
    Dec 2011
    oxford
    Default mirror
    F&%$ing mirror's
    checked the other side when the other mirror fell out and it was fine, not loose at all, now it too has fallen out and smashed.
    As im not sure if the mirrors where original ones or not, what should i have.
    Both are heated flat with drivers mirror having the blind spot line.
    Should i have flat or convex.
    Question from old post.
    vectra c 1.9 cdti 06
    thanks
    des
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    my near side fell out the other day on my facelift just as I was cleaning it after a wash, its was original and was supprised it was reflective on both sides, spray glued it back on.
    The mirror looked flat and not convexed, only the drivers side has the blind spot, convexed mirror iirc
    Regular Member bigbnlr's Avatar
    Belfast
    Mine had convex mirrors on both side before I broke the passenger one
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Common fault on the vec c
    seems to happen when it gets warmer possible because you have used the heated mirrors in the last cold months
    also i find people are cleaning there cars more now
    because its warmer and the mirror falls out on the floor
    vauxhall glue issue
    when your using the hose pipe dont spray it at the mirrors it weakens the glue
    it always happens soon after the car has been washed
    there are hose pipe bans in some areas make sure your area is ok there is a 1000 fine else
    http://www.telegraph.co.uk/earth/ear...-you-1000.html
  1. mirror cover & mirror glass
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 11:27
  2. Looking in the mirror
    By fenderguitar in forum Quick Photo Album
    Last Post: 6th July 2009, 19:29
