Thread: Vibration at speed. ????????
    Dartford
    Default Vibration at speed. ????????
    Hi guys
    Been having a vibration felt through the whole car. At low speed upto 50mph it's ok past that the car seems to wobble. I thought It was wheel balancing so had the fronts done then Took the veccy up to Sheffield at the weekend and noticed that its still there..... No where near as bad but still there. It seems to happen through acceleration and I usually stick cruise on at 80mph being a long journey I had time to listen more and there seems to be a bit of a rhythm to it it's like d,d,d,d,d,d........ D,d,d,d,d,d,d,d..........d,d,d,d,d,d,d,
    Any ideas?
    I didn't balance the rears.... And have noticed on occasion when braking I get a feeling of warped discs but not sure if it's related as discs and pads were replaced last year.
    Anyone else had this and can point me in the right direction. I assume it's nothing major as it just flew through mot but then again.... Suppose it depends on the tester.
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Tracking or worn tyres?
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Usually rear wheel balance problems are felt through the car, front wheel balance problems are felt through the steering wheel, as you have just had the fronts done swap them to the rear and see if the problem moves to the steering wheel
    Dec 2011
    Seaham
    Check for a flat on your tyres. If the car has stood a while there may be aflat across the tyre, also check for any bulges in the sidewalls or any other irregularities.
    Dartford
    All valid points.... Tyres are due for renewal very soon. Might see about tracking then tyre wear seems even though but you never know
    As long as its nothing major I'll stop worrying.
    Regular Member Tom Jerrard's Avatar
    Feb 2012
    dorset
    Vehicle : veccy c 2.2DTI ELITE
    Trim : ELITE
    Engine : 2.2DTI
    Year : 52
    Mileage : 124.102
    Cool vibration at speed
    Hi dont no if it helps but i had that with mine and was told it was drive shafts, so had them changed but was still doing it, i took it too autotechnics and they found the fault was a broken front right suspension spring. hope this is any help.
    Regular Member Matt_NI's Avatar
    Dec 2011
    N. Ireland
    Check your tyre pressures. I have a vibration in mine as one of the front tyres has a slow puncture.
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. Vibration Noise under speed
    By ianplant85 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2012, 19:42
  3. Speed limits & speed cameras.
    By kentish_bloke in forum General Chat
    Last Post: 15th February 2010, 21:22
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. Speed Camera's / Mobile speed traps M6>M61
    By suj786 in forum General Chat
    Last Post: 10th March 2006, 22:38
