Thread: What GSI brake setup to buy?
    Regular Member chickenwing's Avatar
    Feb 2012
    Default What GSI brake setup to buy?
    I need to change my pads, so thought I might as well stick new discs on as well...
    I want drilled an grooved, but not sure what type or where to buy from, any suggestions?
    my fronts are 314 and back are 292 (I think) vented.
    I was just thinking of putting new standard discs on back but changing front to drilled and grooved, thoughts?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    sounds good to me, you can always get police spec pads from VX to go with the new discs
    West Yorkshire
    What is car used for?
    Don't bother with drilled and grooved
    You will get better performance from simply using new pads and discs
    My current front discs are at the end of their life, and I can feel it!
    I am just waiting for the front pads (third set to these discs) to wear out
    The difference with new pads and discs is considerable
    Personally, I think the pads lose their perfomance once they are about 70% worn
    I've also compared standard and police spec front pads, didn't notice any difference, they lasted about the same
    30K / 26K / 18K miles and 25K / 21K / (estimated 20K on present set) on each change
    They should both be ventilated, 314mm on front and 292mm on rear
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    If you can get drilled and grooved discs at a relatively good price go for it. Otherwise just stick with the standard discs and uprate the pads to a high performance pad. QFM, RDA etc. If all you intend for the car is to drive it on public roads and not track it.
    Feb 2012
    Thanks for advice.
    My car is just a road car, possible at some point my take it on a trackday though.
    My discs are worn, but pads are relatively new.
    I just fancied a change.
    I've found original discs and pads for @ £150 (all for corners)
    Quote Originally Posted by chickenwing View Post
    That's about the same as from most dealerships, as pad and disc kits are heavily discounted
    West Yorkshire
    I'd stick to standard stuff for the road
    Feb 2012
    Quote Originally Posted by wazpaz View Post
    Cheers, I think that's what I'll do. Do you know an easier way of confirming my front disc size, apart from taking the wheel off and measuring? I have rear vented discs, so they must be 292. Just not sure if fronts are 304 or 314.
    West Yorkshire
    What year is car?
  1. For Sale: 314mm Brake setup
    By Harro in forum Parts for sale
    Last Post: 16th June 2012, 14:09
  2. For Sale: 314 Brake setup
    By Sebastian in forum Parts for sale
    Last Post: 4th September 2011, 10:40
  3. For Sale: 314 Brake setup
    Last Post: 6th August 2011, 14:23
  4. Standard Brake Setup
    By paulhb in forum Parts for sale
    Last Post: 29th January 2009, 17:12
