Thread: HELP!! ..2.0dti with spanner through it when warm!!???
    Jun 2011
    Herts
    Default HELP!! ..2.0dti with spanner through it when warm!!???
    as above.... the car starts fine and runs great until it's up to temp and then it drops into limp mode.
    there is a car with a spanner through it when this happens but no engine warning light.......
    having read all similar threads that I could find- I then checked out the vac pipes and they all seem ok. I also took out the crankshaft sensor and cleaned it(it was minging BTW as was all around it) where the lazy mech had spilled oil from the oil filter housing but it hasn't made any difference.
    I cant read the codes as the pedal test doesn't work on my 03 dti.....
    Any ideas on what it could be??
    Steven
    Apr 2012
    Cambridgeshire
    Egr valve maybe?
    Jun 2011
    Herts
    do the symptoms described match a dodgey EGR too then??
    I will try cleaning that tomorrow too as I'm trying to go through the less expensive steps first.
    Any othe thoights??
    Jun 2011
    Herts
    bump.....
    anyone near north/east london with a code reader I could borrow???
  1. Car Spanner Light 2.0dti
    By holtie in forum Engine & Drivetrain
    Last Post: 17th January 2013, 16:37
  2. Spanner through Car warning light - 2.0DTi
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 18:11
  3. help! spanner light! 2.0dti
    By mick p in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:38
  4. 2.0dti - spanner light syndrome!
    By Littleted in forum Engine & Drivetrain
    Last Post: 10th January 2008, 00:23
  5. Signum 2.0DTI spanner light
    By signum_boy in forum Engine & Drivetrain
    Last Post: 17th May 2007, 22:00
