Thread: Blower on Full, won't switch off
    Apr 2012
    Rochester
    confused Blower on Full, won't switch off
    Can anybody give me any pointers? I have a 3.0ltr Td V6 2003 (53 plate) Signum. The Internal blowers are stuck on full, and don't turn off even with the ignition off. I think its down to 1 of three possibilities. 1, the blower resister.
    2, A relay ( if there is one ) or 3. the console itself.
    The last one ( no 3 ) is most unlikely because the heating is still adjustable.
    Any one with ideas or past experience would be most helpful
    East Midlands
    Sounds like its shorting out as well as the resister,?did you check the pollen filter drain could be blocked with debris causing water to find its way in to the electricals.
    The control module has failed
    Although you can still control the temperature, the circuit for the power setting has blown
    Typical when any such module fails, you may only lose one part of it, the rest still works
    Apr 2012
    Rochester
    Quote Originally Posted by macdad View Post
    ok will check this out, thanks
    Apr 2012
    Rochester
    will try out McDads first before going down expensive route. Still doesnt explain why blower on full, as module does go out when ignition goes off but blower still on !!, but thanks
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    try disconecting the battery and leave of for half hour or so fella this does seem to cure lots of electrical gremlins
  1. Blower won't switch off - vectra c 2.2
    By mattrobins in forum Bodywork & Interior
    Last Post: 4th February 2011, 12:11
  2. Replies: 3
    Last Post: 15th November 2010, 13:14
  3. Replies: 0
    Last Post: 21st July 2010, 19:11
  4. Full-on Heater Blower
    By browning in forum Bodywork & Interior
    Last Post: 11th January 2010, 21:51
vectra heater doesnt turn off
zafira a cant turn off interior blower
vectra heater blower wont stop
08 vectra heater wont switch off
vectra heater wont turn on
heater on vectra c staying on when ignition is off
