Thread: EML light when first starting, no fault code recorded???
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    Default EML light when first starting, no fault code recorded???
    My 2.0dti Signum brings up the EML when I first start it. If I rev it above about 2000 revs the light goes out. When scanning with my scanner, no fault codes are recorded.
    Could this be a simple thing like a dodgy glow plug?
    Jan 2012
    Cornwall
    OK. Found the fault.
    Unplugged all of the plugs and tested each one with a multi-meter. All of the plugs read 0.9 ohms to ground apart from one which was open circuit.
    I replaced it and now I haven't got the EML when I first start the car.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    one of the glow plugs was dodgy?
    Jan 2012
    Cornwall
    Yeah, one of the glow plugs was open circuit. Sorry, I referred to them as 'plugs' in my previous post.
    Regular Member Led's Avatar
    Kings Langley
    Red face
    My Vectra 2.0DTi has the same symptons - how did you get the electrical connector off the glowplugs ?
    Jan 2012
    Cornwall
    You have to squeeze really hard on each side of the connector and pull upwards.
    Kings Langley
    Thanks - I'll give it a try when the weather improves.
  1. Replies: 2
    Last Post: 10th September 2012, 19:09
  2. Fault Code Pic - Anyone wanna shed some light
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 17th March 2012, 08:11
  3. Emissions Light - Fault Code Help!!!
    By Stu_2010 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 23:48
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
  5. ECU Light & Fault Code help!
    By petesaysblimey in forum Engine & Drivetrain
    Last Post: 24th September 2008, 15:03
