Results 1 to 10 of 19
Thread: Rear suspension woes AGAIN!
    Regular Member Keif's Avatar
    In the Garage
    Default Rear suspension woes AGAIN!
    It's happened again....
    Had a rather loud creaking coming from the rear of my car, loud enough for pedestrians to turn round to see what the noise was.
    So on investigating what was the cause on Friday I should have known what the issue was.
    Can you guess the problem?
    I originally bought a replacement pair in July 2011 from eBay, after a grand total of 4 months, the bushes were perished/split and the seller on eBay honoured the Life time warranty on them and replaced them FOC and at the end of November 2011 I fitted a nice shiny new pair!
    Well 4 months down the line again, i've now contacted the seller again and under the Lifetime warranty asked for a full refund.
    Powerflex order placed and I'll add the progress in fitting them on here.
    i would like to note another thing that this forums brilliant for. A quick search on here for my posts around the middle of last year. I found a reply about the torque values on the How to, so knew what month I originally ordered them. Then could trace back all the details to inform the seller.
    Thank You Vectra-C.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I wish I had not seen this thread becuase it looks like another upgrade.
    Are you saying there are now powerflex bushes for the banna arms? If so where from and how much am I going to be spending
    In the Garage
    Yes mate. Powerflex now do all Vectra/Signum suspension bushes.
    www.powerflexshop.co.uk seem to be the cheapest. I've rang them and checked their prices listed are per CAR not per bush.
    As for cost...alot! £140 just for the 4 bushes.
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    I'v got some rear upper arm bushes and the outer ones don't fit my arms! so still got to buy another set of arms with a bigger bush on the end to put the powerflex ones in ! I'm not 100% but I think they have been changed at soon time and not the right ones or of another model but they are gm ones !!
    In the Garage
    Any chance you can measure the diameter of the Stainless Sleeve for the outer bush?
    I'll see if they'll fit into the Rear Upper Arms I have here (with the bushes striped out)
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Some pic of what i mean and don't no if any one can tell by the part number if they are right arms
    Sent from my iPad2 using Tapatalk HD
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The part nr. on the black one match up with a Vectra C facelift.
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Any one got any old arm's with that size hole that I can have or for a small fee !!
    In the Garage
    I've just checked my "spare" arms that are getting the Powerflex bushes fitted, and from the measurements above, they WILL fit.
    Quote Originally Posted by keith150882 View Post
    so still got to buy another set of arms with a bigger bush on the end to put the powerflex ones in.
    I was going to throw my existing pair (still on the car creeking like ****) when i've got the replacements bushed and fitted. You're more than welcome to have them (for Postage cost).
    Might be worth contacting Powerflex directly too. Looks like they made them to fit non GM arms.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    maybe the bush size is the difference between the facelift and pre facelift arms
  1. Front suspension woes
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 20:52
  2. Replies: 10
    Last Post: 1st June 2011, 14:43
  3. DTI 2.2 Rear suspension
    By Desmo in forum Engine & Drivetrain
    Last Post: 18th September 2009, 16:57
  4. gsi 3.2 rear suspension
    By muller73 in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2009, 00:06
  5. rear suspension
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:34
