Thread: Siemens NC DC 2013
    Regular Member splott's Avatar
    Mar 2012
    Wirral
    Default Siemens NC DC 2013
    Help! Does anyone know how to release the multi CD cassette which is jammed in. I can just about see it and it looks like it has burst at the front edge. I can remove the fascia but can't get any further.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    cant you wiggle it from the front... on mine sometimes i need to push it slithli downwards to make it pop out...
    Else you need to take radio completly appart...
    Mar 2012
    Wirral
    Quote Originally Posted by kenp View Post
    I can't get it to move at all. So I'll need to strip the radio but not sure whether it can be done in the car or when its removed. Thats the crunch how do you remove the radio?
    Engine : 2.2 Direct
    you cant do it in the car..
    You will have to remove it.. how to remove it use appropriate removal tool.
    Mar 2012
    Wirral
    I have the required tool but all it seems to do is release the front fascia. Do you think I'm doing something wrong?
    Engine : 2.2 Direct
    well it can be a pain to get out..
    normaly i also take the screen out to push from behind while i try to remove it.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    I pull out the heater panel and then push the head-unit out from underneath.
    The heater panel usually pulls out quite easy, whereas the display requires trim strip removal and then undoing 4 torx screws.
    Mar 2012
    Wirral
    Quote Originally Posted by Robsey View Post
    I'll give it a try Cheers
  1. Siemens NCDC 2013 changer problem
    By RobertsVectra in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 23:56
  2. Help Siemens NCDC 2013 Sat Nav Disk
    By Whoosh in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 14:44
  3. siemens 2013 disc
    By MORGIE8153 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2010, 08:27
  4. Siemens ncdc 2013
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 21:07
  5. siemens 2013 satnav map with TMC?
    By vectrasri03 in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2007, 16:29
