Results 1 to 10 of 17
Thread: How can we change the interior light to LED instead of soffit bulbs?
    Apr 2012
    Turkey
    Default How can we change the interior light to LED instead of soffit bulbs?
    Thank you for your answers
    I want to do this changing a lot
    Jul 2011
    UK
    Year : 06
    Do you mean so you have bright crisp light inside car if so go on eBay and search for a 48 led panel they plug in ya normal 501 bulb socket I have them and in the rear I have a 13 led panel
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i got a couple of these 48 led panels and the only thing i would say is that you can clearly see its 48 leds through the frosted panel thing.
    i wasnt so keen on that
    Mar 2012
    Walsall
    i found the 48 led panels were too bright.. the 12 LED ones were brilliant however, i have 2 in the rear and 1 in the front. the 2 48's were perfect for in the boot however.. which gives an incredible amount of light...
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I find standard 501 LEDs best, get the inverted lense type tho so you don't get the halo on the light lense.
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by lh_4827 View Post
    You got pic of the brightness I do actually find the 48 in front 2 bright I have 2 12 led in rear light was thinking maybe 24 in the front
    Jun 2006
    St. Helens,Merseyside
    im using 2x these in the front
    and 2x these in the rear
    and these in the map lights
    not from the sellers in the links
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Where did you get them from? Do they fit in the light holders properly or is there any modding to do?
    These will look good with the blue led conversion and extra light in the boot will be a winner
    Apr 2012
    teeside
    Thanks mike. ive used the ones you said in the post above in my vectra and it looks alot better.
    Only thing thats stange is that when i unlock the car the front big light no longer comes on unless i press the button second from the right then unpress it. It sort of flickers on then off when pressed once then when you unpress it it stays on?. i remember reading somewhere on this forum that it is a common thing for smd lights in vectras though so not too much of a biggy.
    Again thanks for the advice mike. Onto the headunit and reverse camera now, then going to try and repair the wing mirror controller as the up down left and right has a mind of its own.
    EDIT: @pompey-pimp mike has put ebay links in the post if you look closely. Also they are T10 so they go staight into original sockets. I had to take my sunglasses bay out though in order to push the bulb board down when inserting them as it was bouncing when i put pressure on to insert.
    Mar 2012
    Walsall
    Quote Originally Posted by pompey-pimp View Post
    no modding, all panels come with the relevant adapters to convert to festoon, soffit or normal metal based bulbs:
    http://www.ebay.co.uk/itm/1906266441...84.m1497.l2649
    thats the exact kit i used for the boot lights. you cannot fit them inside of the boot light itself, but you can stick on the outside of the boot light, tucking all wires away..
  1. Interior light bulbs
    By *rob* in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2012, 18:08
  2. interior light bulbs
    Last Post: 3rd January 2011, 21:42
  3. interior light bulbs what to go for????
    By vectragsi3.2 in forum Styling
    Last Post: 13th April 2010, 19:55
  4. Interior light bulbs
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2009, 12:40
  5. Bulbs & interior light. FS.
    By Caterman in forum Parts for sale
    Last Post: 7th September 2007, 00:38
how to remove interior lights on vectra c
https:www.vectra-c.comforumshowthread.php160672-How-can-we-change-the-interior-light-to-LED-instead-of-soffit-bulbs
