Results 1 to 10 of 11
Thread: 22 dti 1105
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default 22 dti 1105
    hi all..
    iv gone into limp mode a few times latley and the code reader comes up with a 1105 barometric type code.
    where do i start as i think its a boost problem but im unsure.
    cheers
    al.
    West
    Start by cleaning the boost sensor & the inlet
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i think its inlet manifold off time now its getting warmer.
    il clean the boost sensor this afternoon.
    cheers
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i cleaned the boost sensor but it didnt look that bad?..
    il see if the fault returns tomorrow as iv erased all the codes
    al.
    Full Member paul.sessions's Avatar
    leighton buzzard
    Check for split pipes too
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    hi all..
    no split pipes anywhere and after cleaning the boost sensor, it drove ok with no limp mode this morning si it looks like its done the trick !
    cheers
    al.
    West
    Remove the alloy elbow which the boost sensor sit's in... the amount of gunk in there is unreal
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    the intake and egr are due to be removed and cleaned when the "good" weather returns lol
    al.
    leighton buzzard
    Nottinghamshire
    P1105 is barometric pressure sensor circuit malfunction.
    The barometric pressure sensor is the black square one that clips on to the back of the air filter box. It has a small Motorola 'M' on it. Barometric pressure refers to the 'ambient' air pressure around the car, not that in the inlet manifold. Presumably the ECU uses this as a reference point when working out what the pressure should be inside the air pipes.
    Might be worth checking the connector is properly fitted, and is clean and dry inside. Also remove the sensor from the bracket and check that the hole underneath isn't obstructed.
    I had this fault once and did the above. The fault hasn't come back yet so hopefully re-seating the connector did the trick.
  1. Barometric pressure - 1105 FA, 0105 FA and a few other codes :)
    By influencd in forum Engine & Drivetrain
    Last Post: 21st February 2011, 22:21
22DTI
