Thread: Coolant light and subtle loss
    Apr 2012
    Cambridgeshire
    Default Coolant light and subtle loss
    Hi all, thank u for taking the time to view my first post. I have recently bought my first vectra c, a 2004 2.0 dti active, done 175k but full service. On bringing it home the low coolant level light came on, topped it up, didn't drive for a few days until I got tax sorted, next time I drove it coolant light came on again, had lost about an inch out of expansion bottle. The coolant inside the bottle is a murky brown colour with a film of crud on top, also when under load earlier the temp gauge went up from 80 to 90 then back to 90. Have it booked into garage next week but wondered if anyone could point me in the right direction please? I'm thinking head gasket but also possible heater matrix or oil cooler? No obvious signs of leakage either.
    Thank u for ur time
    Dec 2011
    Seaham
    Get a pressue test done, I would suspect a head gasket failing.
    Apr 2012
    Cambridgeshire
    No Mayo under cap nor smoke that's what made me wonder to be honest. I'm having some sort of chemical test done on it? What's worst case scenario please, £ wise as I've only just bought it, not sure whether to cut my losses or not?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Would be worth draining, flushing, and refilling the cooling system. Also flush the radiator.
    Failing that, it's the head gasket
    Also......
    Apr 2012
    Cambridgeshire
    Thank you for your time. Will the chemical test thing highlight the problem if it is head gasket? Sorry for all the questions, not particularly useful with spanners I'm afraid.
    Apr 2012
    Cambridgeshire
    Also forgot to add that the bottle seems under pressure from cold? Not good I think?
    The chemical test lets you know if there's oil or fuel in the cooling system , as stated above a good flush is the best start
    If there is fuel or oil in the water then it's 99% that the head gasket is gone
    Sent from my iPhone using My thumb
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Trevor123 View Post
    Head gasket
    Apr 2012
    Cambridgeshire
    Hi, thanks again, just been out to the car, I seem have a small collection of water on top of the gearbox just under the bottle in some small pockets that are on the casing? It's warm too. Sorry for all the advice required. Thank you to all that have replied so far.
    Dec 2011
    Seaham
    Check for a split in the tank or a duff pressure cap. Although if it is constantly under pressure, still think you need the head gasket looking at?
  1. V6 Coolant loss, Help!
    By v6boy in forum Vectra C / Signum Troubleshooting
    Last Post: 12th September 2010, 16:01
  2. Coolant loss 3.2 V6...
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 11:31
  3. Coolant loss
    By monkeyhinger in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 23:42
  4. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
  5. 1.8 coolant + oil loss
    By Aleco in forum Engine & Drivetrain
    Last Post: 15th March 2007, 21:52
