Thread: whats a DMF??
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default whats a DMF??
    Whats a DMF?? what does it do and how would you know it is on its way out..?? and how much does it cost??
    Sorry for all my questions and threads lately, Im trying to get familiar with my car & parts etc
    Dec 2011
    Seaham
    Dual Mass Flywheel, it helps to dampen down the vibrations on modern diesel engines.
    You get vibrations at low revs, car can be difficult to start, normal clutch problems, hard to change gear etc
    About £7-800 as you also need to change the clutch etc
    Regular Member *rob*'s Avatar
    Mar 2011
    Club-vaux, Moderator
    Engine : Y30DT
    Dual mass flywheel, sits between the clutch and flywheel to help transition the torque of a diesel engine
    When your sitting on idle and it feels like its slightly misfiring but it's not it's your dmf unbalanced slightly and wearing out
    Was told its about a grand to do at a garage
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    you can pick a clutch and flywheel kit up for about £450+fitting
    Nov 2011
    Buckinghamshire
    oh gosh!! That dear
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Had to do mine not long after getting mine £800 for DMF clutch and master cylinder replacement. Symptoms were clutch pedal went to the floor and would not come back up, rattling nous from the engine at tickover and heavy vibrations felt through the clutch pedal.
    Sodding Typical on Sea
    Put another way to answer your question
    It's a whole pile of stinking poo trouble that some bright spark invented, that costs us all a fortune in the end !!!
    Nov 2011
    Buckinghamshire
    i was thinking that Derek!! theyre always adding some stupid things to cars, Crazy!
    Quote Originally Posted by SarahP View Post
    You get DMF issues on almost every make and model depending on how the car is driven, you can "feel" it at work if you make a particularly harsh gearchange or if you leave it a bit too late before dumping the clutch when you stop it gets all soft and wooly feeling you also know you have one when it goes wrong!
    Dec 2011
    Seaham
    Most modern diesels have DMF's so you probably would have had similar problems with a Peugeot, a Mazda, a Ford etc
  1. Whats in the box
    By bigmac in forum Insignia Chat (READ ONLY)
    Last Post: 21st September 2011, 18:08
  2. Whats in the box?
    By Ginge7289 in forum Styling
    Last Post: 19th September 2011, 22:00
  3. Another whats in the box..
    By blue estate in forum The 'Off Topic' room
    Last Post: 10th May 2009, 21:54
  4. whats best to use?
    By Mads in forum Detailing and Car Care Discussion
    Last Post: 26th July 2008, 01:04
  5. Whats The Name
    By lilangel in forum General Chat
    Last Post: 8th April 2008, 20:21
