Thread: CDTi 120 timing marks & water pump
    Regular Member R33Leroy's Avatar
    Mar 2012
    Canterbury
    Vehicle : Vectra C 1.9CDTI Energy Ltd Ed
    Trim : FOR SALE PLZ CHK OUT Ebay
    Engine : Z19DT
    Mileage : 119000
    Default CDTi 120 timing marks & water pump
    Hi All,
    As suspected my water pump bearing is shot, 1st time I've attempted a cambelt change always been flush to leave it to the pros, but just cant find the money for a garage visit, hence taking the plung, I followed the 150 how 2 which has helped loads, although as its not a giude for the 120 i see there are some areas which are diffrent.
    1 - timming mark on crank lined up, cam pulley will not line up no matter how many times i turn ovar by hand?
    made my own marks b4 touching tensioner
    2 - water pump was a pig to remove as very tight behind cam pulley?
    (dont want to force new pump in same as removal as it will be wrecked)
    3 - Once i was happy tht i would be replacing new belt correctly i realized as water pump was so bad has the belt jumped a few teeth explaning why oem timming marks would not line up
    Any help ppl i would be very greatful
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    The crank pulley marks are not meant to line up as these are not the timing marks!!!
    East Ayrshire
    Trim : SRI XP1
    If it was running ok beforehand, get a tub of tip-ex out an make your own marks. I'd put 2 on each pulley
    PRESTON
    As i understand it when replacing the water pump on the 120, the cam pulley needs to be unbolted to gain access. Most times you would slacken the cam pulley bolt before removing the cam belt. As has been said, the marks on the pulleys are NOT all timing marks, you need to get the cam locking and aligning tool to set the timing correctly, as there are no marks to line up on the crank pulley.
    Mar 2012
    Canterbury
    Engine : Z19DT
    Mileage : 119000
    Thanks for your replies, I have already marked crank and cam, as my original thought was as long as pulleys are in same pos b4 removal i will be fine, and it turned over by hand without any mech lock up, can the z19dt slip a couple off teeth without causing any damage? thts my main consern that i maybe need to reset the timing if damaged water pump had allowed timing to be out of syc?
    its quite possible that the timing is fine and she not slip any teeth, but i would like to be 100% sure, is there a way to check this without a locking tool?
    Gonna use old belt to try n help crack off cam pulley for water pump refit
    thanks again ppl im less stressed after seing ur posts confirming crank marks are not timing marks so i will use my own that were added before belt removal
    East Ayrshire
    Trim : SRI XP1
    If theres no lock up and it sounded fine/running smooth then it will be fine. you'd know if it had slipped teeth
    Mar 2012
    Canterbury
    Engine : Z19DT
    Mileage : 119000
    Thx stevie for your reply, all was going well this am, tensioned belt, turned by hand no lock up, retensoined belt as advised in gates guide and something defo moved when undoing tensoiner to re-adjust, retensioned and turned by hand now sounds like valves are somewhere they shouldnt be, it's locking up is it mobile mechanic time lol
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Is there a key on the end of the cam for the sprocket to loacte into? Ive replaced several belts on petrols in the past but I do remember on Diesel Astra of my mates that didnt have a key on the cam/pully and needed some special tools to time it with, he didnt have them needles to say it ended up in the bin.
    East Ayrshire
    Trim : SRI XP1
    I'd release the tensioner again and line up your marks, then get the belt put on again properly maing sure the marks are lining up and reset the tensioner
    Mar 2012
    Canterbury
    Engine : Z19DT
    Mileage : 119000
    All sorted thx ppl, didnt wanna risk it after it had moved so borrowed a crank locking tool, n timming marks were spot on better safe than sorry, motor running sweet
  1. Replies: 29
    Last Post: 25th July 2012, 22:52
  2. This mornings job: CDTI 150 Timing belt kit and water pump, with Pics :)
    Last Post: 2nd July 2012, 19:51
  3. For Sale: 3.2 v6 Conti Timing Kit + Water Pump
    By Turion in forum Parts for sale
    Last Post: 4th January 2012, 21:59
  4. timing belt and water pump
    By Garfo in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 21:08
  5. CDTi 150 Timing belt & water pump
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 16:00
z19dt timing marks
vauxhall vectra 1.9 cdti 120 timing belt change
vauxhall insignia timing marksastra 1.9 cdti 120bhp cam timing settingsvectra 1.9 cdti timing markstiming marks on 1.9 vectra 2008vauxhall signum 1.9 diesel ignition timingwater pump cdti 1.9opel 1.9dt timing belttiming marks vauxhall zafira. vauxhall zafira timing markstiming marks 1.9 cdti 150z19dt timing belt changevectra c diesel pump removalhow to remove astra 1.9 cdti cam pulleyvectra 2008 diesel timingvauxhall vectra 1.9 cdti timing belt marksvectra 150bhp timing marks on enginehow to remove a crankshaft pulley on 2008 opel astra 1.9cdtitiming marks dont line up on opel astra cdiwaterpump bearing vauxhall cdtiopel safira diesel how to change water pumpz19 dt water pump removal procedurewater pump vauxhall zafira 1.9 cdtiastra cdti 1.9dt engine block diagram
