Thread: Position of glows
    Regular Member ANDY GSI's Avatar
    dumbarton,scotland
    Question Position of glows
    Hi all does anyone know if the glow plugs should all be in line or do the two outer plugs screw down more than the inner two? Just noticed my two outers screw in further hence sitting lower, is this correct?? 1.9 sig 120 8v cheers
    Jun 2011
    Herts
    sounds odd- I'd assume if they would all be inline- unless they follow the shape of the engine and that isn't 'flat' so to speak.
    Did mine on the dti and although I thought the were all tightened right down- I had a close look and 2 were not down tight so i gave them an extra couple of turns- which sorted it.
    If they are working then i'd leave them be until they need changing, as they tend to be kind of cross threaded after fitting and self seal anyway (form what I saw on mine).
    I'm guessing whoever fitted them probably didn't want to risk snapping one off so eased off the tightening when they really started to bite.
    HTH :-)
    dumbarton,scotland
    I just changed them last week but the old ones were sitting the same way. The two in the middle r as tight as I dare go but still sit 3 or 4mm higher than the outers?
    Engine : 1.9 CDTi
    If they are sealed and not leaking dont worry about it.
    dumbarton,scotland
    That's the thing mate I am having problems with the car taking ages to start in the morning or after work and wonder if this has somthing to do with it? So I need to know if the position of them sounds correct.
    Jun 2011
    Herts
    did you try putting some anti seize copper grease on the threads before turning them in?? also once they start getting tight it is a good idea to unwind them and regrease and re insert them.
    that was advice from a darts mate of mine who is a mechanic in Luton. It worked for me :-)
    HTH
    Aug 2010
    Leeds
    Take them out and test them on the battery they should glow for 3 seconds no more or they melt.
    Wire brush up the threads and a smear of copper slip on threads put them back in if ok.
  1. +12v on key position 1
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 04:36
  2. Monitor position
    By Rands100 in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2011, 16:40
  3. Anyone else been in this position
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 12:22
  4. Cam position sensor
    By kman247 in forum Engine & Drivetrain
    Last Post: 24th July 2010, 18:48
  5. sat nav position
    By deg in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2008, 20:43
