Results 1 to 10 of 26
Thread: Egr blanking plate
    Regular Member G4GAV's Avatar
    Bristol
    Default Egr blanking plate
    Just a quick one chaps, I fitted a egr blanking plate today, does it matter what way it goes on? I mean with the gasket on, off? Above the gasket or below the gasket? Am I just being a gimp here? Don't anwser that one? Lol
    Regular Member farley2708's Avatar
    antrim n.ireland
    you mean the 'square 1' or the 'oval 1'?
    Bristol
    The oval one
    Nov 2010
    East Midlands
    Trim : design
    The original gasket seals the flexible pipe to the body of the EGR - so whichever side you put it on the other side will not be sealed - ideally you should have two one each side of the blanker - when I did mine I made the blanking plate out of copper and softened it so that it would seal to both sides - not sure how critical a perfect seal is - I suppose you could use a liquid gasket on either side to make sure.
    Bristol
    mines a alloy plate and so is soft anyway, i have kept the seal on the the bottom as it is kind of lipped to fit the pipe below and placed the plate on the top of it and so far a good seal but was wondering if i have done it the right way?
    Bristol
    i give the egr a kind of good clean also while off
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by G4GAV View Post
    Should be ok if its soft metal
    Bristol
    Can someone tell me what the difference is between the plates a solid plate and one with a hole in the centre both of them oval?
    I've just seen the other one on eBay and now it has got me wondering if I've ordered the right one.
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    The one without the hole might throw up an EML one with still lets air through but reduces the probability of blockage.
    Nov 2010
    East Midlands
    Trim : design
    Hi, Thanks for the thanks - you could always drill a 10mm hole in the centre of the plate you have. As already said the hole prevents you getting fault lights on your dash - although some members have fitted ones w/o a hole and they have not bought up any faults.
    There is also a 'Fiat' type gasket that has 3 x 6mm holes in it that is supposed to be an improvement on the one hole type.
    I would be tempted to try your blank plate w/o a hole first and see what happens - if a fault comes up you need to have the EGR mapped out (expensive) - or you can then modify your plate by drilling a hole and refitting.
  1. For Sale: DTi EGR Blanking Plate
    By TonyP2020 in forum Parts for sale
    Last Post: 8th November 2012, 00:10
  2. Egr blanking plate
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
