Results 1 to 10 of 22
Thread: boost sensor on the 120
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default boost sensor on the 120
    Hi where is the boost sensor on the 1.9 cdti estate (120)
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by SarahP View Post
    Between the body of the EGR valve and the engine/manifold at the rear of the engine - you need to remove the EGR to get access to the one bolt that holds it in place and then pull it out. If your thinking of cleaning it be very careful as its quite delicate - use carb cleaner and a small soft tooth brush to clean it.
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    No need to remove the EGR to get at it (not on my 120 anyway).
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Samdy Gray View Post
    No not if you've got a very short allen/torx key - a lot easier if its out the way
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    You can use a torx bit and a pair of pliers there is just enough room, but slit easier if you undo the egr retaining bolts.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Casey View Post
    Mine is held in place with a torx bolt but my mates I did the other week had a hexagonal allen screw - wouldn't have thought you could get it tight enough with a pair of pliers.
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Mileage : 100k
    It doesn't need to be tight, the sensor is held in position by its O ring, the retaining screw only needs to be nipped up. So many things get over tightened these days causing many a headache.
    Nov 2010
    East Midlands
    Trim : design
    Yea true - but if its not tight enough the vibrations of the engine will soon shake it loose - the O ring is a tight fit but that is intended to be a seal not to hold it in place. I suppose if you had the inclination you could find the correct torque setting for the bolt and tighten it to that setting.
    Nov 2011
    Buckinghamshire
    Thanks peeps... where do you get the carb cleaner from?
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    http://www.ebay.co.uk/itm/Choke-and-...item416433cf54
    or
    http://www.ebay.co.uk/itm/500ML-CARB...item58928cd185
  1. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  2. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  3. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
  4. BOOST SENSOR, where can I get 1 and how much?
    By VXR CDTi in forum Diesel Engine related
    Last Post: 12th November 2008, 16:20
