Results 1 to 10 of 16
Thread: Brakes and calipers
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default Brakes and calipers
    Hi.. could having to bleed your brakes every 8ish weeks mean there's something wrong with a caliper? I asked a garage (over the phone) and they said yes its probably seized/sticking you will need a new one but you HAVE to change both sides at the same time.. he quoted £260 ..
    1) Is this correct, cant I just have the bad one replaced?
    2) Is it always down to a caliper when you get air in brakes alot (no loss of brake fluid, all pads/discs etc are fine)
    3) when engine is off and stationary I can hear a creak if I press brakes
    4) Is it really £260 ????
    Sorry lots of questions here
    Regular Member gibbon7000's Avatar
    lincs
    I'm no expert on brakes, but I really can't imagine you would need both callipers changing. Think they are trying it on. I'm sure someone will correct me if i'm wrong.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Fronts or rears? The rears can stick but I not heard anything about the fronts sticking. Also you can get refurbed ones from VX at a good price
    East Ayrshire
    Trim : SRI XP1
    You can def change one at a time. However, As for air getting in, but no loss of fluid, It may well be a seal on the caliper but it could also be an internal leak in the master or slave cylinder. I think i'd be popping it in to somewhere that can do a proper diagnostics on it
    Nov 2011
    Buckinghamshire
    Hi.. thanks for the replies, aparantly i was told it would be the fronts
    It all started when the front brakes were changed about 18 months ago, before they were changed there was no problems at all
    Nov 2011
    Buckinghamshire
    How much are calipers and where do you get them from? Thanks
    You get the calipers from the dealers , just ask for a refurbished calipers , but before you buy anything get it looked at by a decent garage not Kwik fit etc
    Sent from my iPhone using My thumb
    Nov 2011
    Buckinghamshire
    why not Kwik Fit? are they rob dogs? (ive never been there by the way)
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by SarahP View Post
    Quick answer yes, far better going to a local independant garage for advice.
    3.2 v6 Signum and loving it
    East Ayrshire
    Trim : SRI XP1
    It sounds to me like whoever changed the brakes has maybe forced the piston back into the caliper and flipped a seal. It's unusual for the vec but definitely possible.
  1. For Sale: 302 brakes and calipers
    By daddyjay in forum Parts for sale
    Last Post: 5th February 2013, 21:56
  2. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  3. Updated phone, rear brakes and repainted calipers
    By mattv6diesel in forum Quick Photo Album
    Last Post: 6th March 2012, 19:19
  4. 302mm brakes, calipers and pads
    By Matt&Jemz in forum Parts for sale
    Last Post: 17th November 2009, 19:04
  5. New Rear Brakes And Painted Calipers
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2008, 22:48
