hi ,its on z22yh engine ive got 2 little problems , please someone whos put in new spring or checked there spring and plunger please comment.
1st problem,the new spring is 5mm longer is this normal.
2nd problem,when you come to screw in bolt its a long way from hole and you have to press really hard and turn at same time to be able to start the thread to bite .it took half an hour and fingers hurt like hell . is it normal for spring to stick out a bit and have to put so much pressure on the bolt to get it to screw back in ,or is there an easyer way or am i doing something wrong .the plunger glides up and down freeley.
