Results 1 to 10 of 18
Thread: aircon
    Regular Member eminemme42's Avatar
    Jan 2012
    westmidlands
    Default aircon
    how can you tell if the air con is working how cold does it get
    vectra c sri 1.9cdti 54 reg
    any way to test it is working correctly
    cheers pete
    11 Post(s)
    The AC pipes under the bonnet should have condensation on them.
    Something like 4 to 6 deg C measured at the dash face vents.
    Sep 2009
    Glasgow
    as above while driving around 6 degrees , stationary about 4.2 on mine anyway.
    Barrow In Furness, Cumbria
    The revs will fluctuate slightly when turned on and you should hear it kick in. Also the inst fuel cons may go up to 0.3 gal/hour. There should be enough of a difference to feel the change in temp on your hand after a minute or so. (depending on outside temp).
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by eminemme42 View Post
    cheers pete
    have you got climate or standard?
    Jan 2012
    westmidlands
    how can you tell
    climate r standard
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    climate you can alter want temperature you want in the car
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    if its not getting cold enough you may find it needs re-gassing
    mine did the same i took it to nationwide autocentre costs around 50 pounds
    you could ask them to check it
    Jan 2012
    westmidlands
    no just standard
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    mine is standard as well
    when you press the button the cars rev counter drops a bit it takes a bit of power out of the engine
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Aircon
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 20th June 2012, 18:18
  3. aircon help
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 01:33
  4. Aircon
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 27th November 2008, 19:04
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
