Thread: clocks dying
    Apr 2012
    edinburgh
    Default clocks dying
    hi guys got a problem 5 mins after driving my clocks dye and the battery, abs and engine light comes on but car still drive great sometimes the radio goes off but not all the time ive tried a voltage meter as someone suggested the altenator but according to the meter its a 14 so then today i bought a fault code reader as the engine light comes on but that came up with airflow meter so fixed tht but clocks still dye
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Check fuse 19 + 26 on passenger side fusebox, pull em out, make sure they are ok, if so clean and replace. Also check abs plug under bonnet
    Apr 2012
    edinburgh
    abs plug under bonnet where will i find it please xx
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    HERE you go.
    Apr 2012
    edinburgh
    thank you very much xx
    Vehicle : SRi
    Mileage : 137000
    If your car is a prefacelift its more than likly the ABS plug, if not that then check the other things listed, other than that it could be your CIM but thats the worst outcome.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I still bet it's the Alternator. Get it on an alternator and battery tester. ATS did mine. When it gets to a point that the Power steering pump cant work, you'll know about it. If Alternator and batt are good. It'll be the CIM. (Testing battery and alternator will be cheaper than swapping out the CIM)
    Apr 2012
    edinburgh
    yea its the facelift model x
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It could be a CIM problem
    Apr 2012
    edinburgh
    ive tested battery and altenator def not them will do the others in morning xxx
  1. 140mph Clocks To 170mph Clocks
    By Lean6 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 20:48
  2. is my dmf dying
    By neill in forum Engine & Drivetrain
    Last Post: 20th December 2011, 10:00
  3. A Dying Man
    By xoborp in forum Comedy & Humour
    Last Post: 26th September 2011, 08:58
  4. I am dying – Man Flu!
    By coldo in forum General Chat
    Last Post: 10th October 2010, 17:53
  5. ..........I'm dying !
    By FIL 4822 in forum General Chat
    Last Post: 5th October 2008, 20:02
