Results 1 to 10 of 11
Thread: please i really need help with parking sensor wires!!
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default please i really need help with parking sensor wires!!
    sorry to keep banging on about this but i really need help with the wiring.
    i have front and back parking sensors, i have run all wires to the boot inc the 2 wires from switch on dash, i need to know where the following wires can go in boot terminals
    positive wire +12v
    neg wire -12v
    reverse feed +12v
    front sensors +12v via switch on dash (normally connected to brake feed, but i want to use a switch)
    ive done this so far http://www.vectra-c.com/forum/showthread.php?t=11893 but need to know where to put negative and permanent +12v to front sensor switch
    im getting confused because some threads say use socket 2 pin 4 and others say socket 2 pin 3????????
    please help
    Ipswich,.UK
    heres the tread that uses different wires again??
    http://www.vectra-c.com/forum/showthread.php?t=75327
    Ipswich,.UK
    dp.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Right well find a perm live or ignition live for the front sensors put ya negs Down to ground then the rears ones in to the reverse light live and the neg to ground hope it helps mate
    Ipswich,.UK
    Quote Originally Posted by paulvectrac View Post
    i have used pin 2 socket 4 for 12v ign live, i have connected this to the postive to power the sensor unit and joined the switch for front parking sensors to this as well..............is that ok?
    i have used socket 1 pin 1 for reverse live
    need to find an -12v
    will that work or can i not use the same ign live to power the unit and front sensors?
    heres the sockets im taking about in this thread http://www.vectra-c.com/forum/showthread.php?t=75327
    thanks for your reply mate
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Sounds ok to me mate a -12 Is ground which Is 0 volts so basically put ya negs to earth matey and it should work
    Ipswich,.UK
    correction with correct thread attached
    i have used pin 4 socket 2 for 12v ign live, i have connected this to the postive to power the sensor unit and joined the switch for front parking sensors to this as well..............is that ok?
    heres the sockets im taking about in this thread http://www.vectra-c.com/forum/showthread.php?t=11893
    Ipswich,.UK
    dp again
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Dps every where lol like I said mate all sounds good to me just put ya negs to a eart point
    Ipswich,.UK
    where the best place in the boot, any wire i can tap off?
  1. [Z22YH 2.2 Direct] Lambda sensor with 5 wires
    By rodzynx in forum Engine & Drivetrain
    Last Post: 10th May 2012, 22:47
  2. 2.0 DTI MAP sensor wires
    By grabos in forum Engine & Drivetrain
    Last Post: 17th July 2011, 09:30
  3. where to route wires for parking sensors 2003 saloon
    By M0rph in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2011, 18:39
  4. throttle sensor wires
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2009, 10:36
  5. CR sensor (wires-colour and function)?
    By diesel dog in forum Diesel Engine related
    Last Post: 23rd November 2006, 01:33
