Results 1 to 3 of 3
Thread: Alternator or Battery Problem?
    Mar 2012
    Gloucester
    confused Alternator or Battery Problem?
    I've got a falut with my Vectra C and cant quite pin it down.
    Its a 56 plate 1.9 CDTI Elite.
    Last week it started playing up. Lights flickering, ABS and Power steering Light coming on eventually leading to it not starting
    First thoughts was the Alternator as the battery was going flat. Checked the Alternator and wiring and found that the wire had disintergrated and come loose which was worring
    Took the Alternator out, and got it checked. Apparently its fine, put it back in and recripped the wire and reconnected it.
    Ran fine for bout 2 days, but now the lights have started flickering again.
    Checked the Battery Voltage with the engine turned off
    starts at 15v, and increases up to 18.5 volts. Strange
    With the Engine running at idle its around 21v. which seems to be far too high.
    Not sure whats at fault. Battery, Alternator or both.
    Any Help would be great.
    Alex
    East Midlands
    Voltage regulator has packed up on Alternator pal,it should regulate voltage at around 14.5 volts.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
  1. Alternator/Battery problem query....
    By Tony W in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2013, 19:09
  2. Vectra cdti battery/alternator problem help
    By goooba769 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 11:17
  3. Alternator or battery?
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:20
  4. Alternator or Battery?
    By callist in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2010, 20:24
  5. Power Steering or Battery/Alternator problem ???
    By kizalini in forum Engine & Drivetrain
    Last Post: 23rd November 2009, 00:50
