hi .
i got new spring , washer and screwbolt from dealer and i checked part numbers on epc4 and they are all correct.
ive got 2 little problems.
1st the new spring is 5mm longer is this normal.
2nd when i try to screw them up,the bolt is nowhere near the hole because the spring sticks out a bit so i have to put very firm pressure on bolt and turn at the same time. it takes a long time for it to bite and your arms feel like there going to fall off.should there be so much pressure on the spring, is this normal. the plunger goes up and down freely.
