Thread: vec c 1.8 fuel issue
    mansfield
    Default vec c 1.8 fuel issue
    my friend and i did his head gaket on his car, all was running before we started.
    so off we set stripping it down, got down to the head gasket and all was going well.
    head went to be skimmed and collected.
    new gasket on and head replaced, all bolts torqued down, pipes on etc
    but now the probem........
    it wont start, plugged opcom in and its saying:
    P0230 Fuel Pump Primary Circuit High
    so what have i forgot, not done, failed to do.....
    Or is it just coincidence that its gone just after we put it all back together?
    Help guys
    Steve
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    mansfield
    in a fashion it helps.
    we tried moved similar relays around and that did nothing.
    ill try it again in the morning see what that does
    there was no sound from the pump when i switched the ignion on earlier
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Fuse maybe? Fuel pump is in the fuse box in teh boot.
    mansfield
    all the fuses seem to be in tact but i could be wrong. any idea on which fuse it is?
    Full Member Big Sig's Avatar
    Double check all of the connectors are connected correctly!
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Is the timing correct?
    mansfield
    Big sig......... spot on,found out that 1 of the connectors to the engine ecu had been forced on and as a result had bent some of the pins in the unit.
    Straightened the pins out, and hey presto,
    SHE'S ALIVE.......
    Thanks to all of you that have replied.
    Ste
  1. issue after fuel filter change
    By justin32 in forum Engine & Drivetrain
    Last Post: 11th December 2011, 04:42
  2. 2.0 DTi issue - fuel leak
    By viperone in forum Engine & Drivetrain
    Last Post: 19th November 2010, 20:34
  3. 3.0 Dti fuel pump issue
    By Agoogy in forum Engine & Drivetrain
    Last Post: 20th May 2010, 10:51
  4. possible fuel issue
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 18:13
  5. Weird Fuel Gauge Issue
    By DeathStar in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2008, 22:44
